Cisco ACS 4.2 integrated with CA Authminder 7.1
Gurpreet Puri
Hello All,
I have Cisco ACS 4.2 which is required to be integrated with CA Authminder 7.1
I am searching all over the Internet but couldn't found a single document related to it.
Could anyone please let me know if this integration is possible?
Thanks in advance !!!
Gurpreet S Puri
Keep Smiling, Peace :)
(Please Rate Helpful Post)
Regards, Gurpreet S Puri **************************** Keep Smiling, Peace :) **************************** (Please Rate Helpful Post)
7 Replies 7
Amjad Abdullah
If you please let us know what kind of integration is needed and how you want the ACS to work with your CA we can possibly help you better.
Amjad
Rating useful replies is more useful than saying "Thank you"
I have a CA VPN Client that will be installed on all the end customer device. Whenever they logged in via same my traffic is going to pass via ACS to reach CA Authminder.
But, for the same, i first want that my ACS and CA Authminder should talk to each other which is certinaly not happening.
The thing so far I got it that they are both going to talk on RADIUS.
Infact, I have make configuration in both of them with my understanding is correct but not getting result.
Gurpreet S Puri
what is the configuration you have made in ACS?
Hi Amjad,
Under Database > Radius Token options; I added the CA Server and Shared Secret key...
Is there any thing more required to be done?
Gurpreet S Puri
From the Unknown user policy, you have to select the server that you have configured so that when the user is not listed in the local ACS DB it tries the alternate DB that you configured.
Now, if you have the auth fails, let us know whta the failed attempts report say abou the failure reason.
Amjad
Thanks Amjad for your support.
I have spoken with Team and got news that Integration is done.
Gurpreet S Puri
Thanks for the info. Glad that it is working.
If you can please share us your experience and how it was configured that will be helpful for everyone.
