Cisco ACS 4.2 (TACACS+) with Nortel switches as AAA clients
Dear All,
Can we add Nortel switches as AAA clients for ACS 4.2 using TACACS+ ?
If yes, Please suggest me how to configure.
Thanks in advance.
Guna
  • AAA Identity and NAC
Silver
Hey,Does the Nortel switch
Hey,
Does the Nortel switch support Tacacs+?
If yes, go ahead.
Most configuration is going to be on the switch end.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
Hi edwjames,Thanks for the
Hi edwjames,
Thanks for the update.
Yes Nortel switches support Tacacs+.
When i configure Nortel switch as aaa client, the connection status on the client is not coming up with aaa server.
Is there any VSA needed to configure on ACS 4.2 for supporting Nortel switches.
Thanks in advance.
Guna
Silver
Guna,Tacacs+ Does not use
Guna,
Tacacs+ Does not use VSAs.
Radius uses VSAs.
This is what I found online:
http://198.152.212.23/css/P8/documents/100106731
See if this helps.
It has an example associated for server configuration.
In ACS 4, you need to use the shell exec and priv-lvl=<value>.
(Similar to Cisco IOS)
Ed
80
