10-24-2013 05:14 AM - edited 03-10-2019 09:01 PM
I'm in the process of moving our log collector from our primary ACS to a new secondary ACS. I have changed the log collector and that worked ok. I'm now trying to do a restore of the incremental backup taken this morning but nothing seems to be happening. When I check application status I see this
BRSPCR-ACS-APP2-LOG/admin# show app st acs
ACS role: SECONDARY
Process 'database' running
Process 'management' not monitored
Process 'runtime' running
Process 'adclient' running
Process 'ntpd' running
Process 'view-database' running
Process 'view-jobmanager' not monitored
Process 'view-alertmanager' not monitored
Process 'view-collector' running
Process 'view-logprocessor' not monitored
Is this normal when doing a restore??
I can see a backup/restore might be in process
BRSPCR-ACS-APP2-LOG/admin# show restore history
Thu Oct 24 12:39:20 BST 2013:CARS_BACKUP_IN_PROGRESS : -411 : A backup or restore is already in progress
I've had wireshark running on our server where the backup files are located so I could check whether ACS was connecting. I could see it connect using FTP and could see data transfer taking place so am hoping it has downloaed the backup from our server.
The full backup file size is just over 5G
The incremental file sise is 25MB
How long should I espect a restore to take place?
Is there any way of seeing if ACS is actually doing the restore?
THis is our version
BRSPCR-ACS-APP2-LOG/admin# show app ver acs
Cisco ACS VERSION INFORMATION
Version : 5.3.0.40.9
Internal Build ID : B.839
Patches :
5-3-0-40-9
Cheers
Jay
11-03-2013 09:17 PM
Hi Jay,
This link might help you to clear all your queries:
Gurpreet S Puri
Keep Smiling, Peace :)
(Please Rate Helpful Post)
11-11-2013 08:33 AM
Sorry I missed your reply. Unfortunatly reading the manual hasn't helped me. I have raised a call with our support about this and am waiting to get a response.
Jay
11-20-2013 08:06 AM
TAC got back to me and its because I dont have enough disk space to unpack the backup file. I need to configure a NFS staging URL.
backup-staging-url nfs://hostname.domainname:/nfs/cisco
Jay
12-12-2013 09:02 AM
latest update - I managed to get the log restore done today, with assistance from TAC. They used the manual method within the Linux console.
These were the steps taken
- stopped ACS view service on Primary ACS
- compressed acsview51.db and acsview.log (total size around 105 GB) to once file with the size of 7,3 GB
- started ACS View services on Primary
- copied ACS View DB from Primary to Secondary using SFTP
- uncompressed copied archive on Secondary and replaced existing ACS View with copied one
- freed up some disk space on Secondary ACS (from 91% to 34% of /opt partition)
Thanks Jay
