04-30-2008 02:52 AM - edited 03-10-2019 03:49 PM
We are currently running Cisco ACS solution engine 3.2.3.11 and using a Windows Domain Controller as a remote agent.
We now need to upgrade the ACS to 4.1
1. Do I need to upgrade the remote agent on the Domain Controller as well?
2. Can any PC/laptop on the network be used as a Distribution server?
3. After an initial backup and then upgrading to 3.3.3.3 do I need to do another backup before upgrading to 4.1?
Solved! Go to Solution.
04-30-2008 05:00 AM
You can use any PC in the network as Distribution server.
04-30-2008 04:58 AM
John,
Your upgrade path would be 3.2.3--->3.3.3--->4.1.1
You need to upgrade both remote agent and appliance else it wont communicate.
It is always better to have a most recent backup handy , just incase something goes wrong.
I have attached the upgrade steps.
~JG
Do rate helpful posts
04-30-2008 05:00 AM
