Community Member
Cisco ACS for authenticating XP login?
It is possible to use the Cisco Secure Access Control Server to authenticate XP users logging into the local workstation? Instead of an AD domain we would like to use an ACS server to authenticate users. Is this possible?
Re: Cisco ACS for authenticating XP login?
Yes , you can set up ACS using dot1x authentication. User will be prompted to authenticate for loggin to a network.
Is it a wired or wireless network ?
~JG
Community Member
It is a wired network. Will the authentication use the login screen typically used when logging in XP?
Thanks.
- Matt
Matt,
No , that is not possible. Machine authentication is not supported with local ACS database.
~JG
Community Member
With remote access (remote Desktop) would it be possible to use ACS for user authentication?
Thanks.
- Matt
Matt,
Answer is still no. It is not possible.
~JG
Community Member
Is there a situation where I can use Cisco ACS to access resources on an XP workstation?
thanks for your replys!
Community Member
Not directly, you have to configure some NAS in between like pix, but again that would not be resource based access. PIX would check IP and then end out authentication request to ACS.
In other words. Answer is No. I cannot think of any scenario where ACS can be configured resource based authentication.
parminder
Sorry to say , that is again not possible. ACS is not designed to do these kind of job.
Community Member
Thanks again, I appreciate your responses.
Community Member
Can ACS be used to authenticate access to a web page on a server running IIS?
318
