Cisco ACS, single-login and RSA SecurID
we need to deploy the following
1. both internet IPsec VPN and SSL VPN will run from a Cisco ASA5510
2. Users use the same credential as their office Windows AD Domain, aka single-login
3. RSA server has been installed to provide two-factor authentication. User will have a RSA SecurID token and enter token number upon login of VPN
questions:
1. do we need a Cisco ACS?
2. if ACS is optional, what is the benefit of ACS?
3. does ASA firewall talk to RSA or ACS will communicate with RSA?
I guess I need to understand all the necessary components and data flows the high level
thanks
1 REPLY
Silver
Re: Cisco ACS, single-login and RSA SecurID
1- No. You can use the radius function on the
RSA Server itself. However, the radius
function in the RSA Server is very limited,
unless, you use the RSA server appliance with
has Juniper/Steelbelt radius, then it will have
everything you need. The alternative is
to use Microsoft IAS with RSA server.
2- ACS provides much more than what you
required.
3- Firewall communicates with ACS or it can
communicate with RSA if Radius is running
on the RSA Server.
496
