01-05-2012 01:41 AM - edited 03-10-2019 06:41 PM
Hi All,
Currently I am running Cisco ACS 3.2 ,now wanted to upgrade with the latest version along with the Authentication using AD ,could you please share the process/Docuemnt to upgrade the same .
01-05-2012 09:21 AM
If you have an ACS for Windows you can refer to:
If you have an ACS Solution Engine (Appliance):
If you are looking to migrate to the new ACS 5.x you can check:
Hope this helps.
Regards.
03-14-2018 11:12 AM
The upgrade process involves upgrading an ACS server, which includes the Monitoring and Report Viewer and the configuration information in the database.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-8/installation/guide/csacs_book/csacs_upg.html
