Cisco ACS v5.0 with PEAP-MSCHAPv2
I am have problems setting up the Cisco ACS server with PEAP-MACHAPv2. Does any one have a step by step guide to help with this issue..
1 REPLY
Re: Cisco ACS v5.0 with PEAP-MSCHAPv2
I do not have a step by step guide to hand. A few things that come to mind are
1) Define netwrok device
2) Set allowed protocols in service definition and select identity store
3) Install server certificate
One good way to trouble shoot such issues is to Monitoring & Reports: > Reports > Catalog > AAA Protocol
and then select "RADIUS_Authentication"
You will see pass/fail records. For each fail record see failure reason. Also select magnifying glass icon under "Details" and will get step-by-step details so that should see step where processing was stopped and failure returned. Will give input to see what configuration is missing
247
