Cisco ACS Wireless Authentication
steelinquisitor
Hello guys,
I am trying to test the wireless authentication and authorization with my wireless users via ACS 4.2. I have the 4.2 trial version on Windows 2003 for testing. I also have WLC 5508 and 3602i in my lab. My AD/NPS and CA are Windows 2008 R2.
The Windows 2003 is part of the domain; and on the ACS, if I go to External Databse > Database Configuration > Windows Database > Configure
From here I selected my domain, tick "Enalble EAP-TLS Machine Authentication". I also have mapped the domain to the group I created in ACS.
I also chaged the default RADIUS ports to 1812 and 1813 on the ACS.
On my WLC 5508, I created a WLAN and set the RADIUS IP to the ACS IP address. However, I tried to join the wireless network. It keep failing.
I have installed the user cert on the laptop for EAP-TLS. If I changed the RADIUS server on the WLAN and pointed it to AD/NPS that I have, my test laptop was able to join the wireless network via EAP-TLS.
I am a little confuse about the ACS TACACS+. Is TACACS+ used only for logging into network devices for management or can it be used for regular users for authentication and authorization?
For example, a wireless user, which is part of the domain, need to join a wireless enterprise network for his office work. Can I use TACACS+ for this or it has to be RADIUS via ACS 4.2?
yes that's right and it applies to wired as well.
On the ACS, please add WLC as a AAA client with radius (Cisco airespace)
Configuring WLC and ACS for radius settings.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml
You may visit the below listed link to install certificate on ACS 4.2
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/configuration/guide/peap_tls.html
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
7 Replies 7
Jatin Katyal
No, we can't use tacacs+ for wireless. It has to be radius.
So have you added wireless controller on ACS as a radius aaa client?
What all certificates have you installed on ACS server?
What error message are we getting when you point WLC towards ACS and try to authenticate wireless users?
~BR
Jatin Katyal
~Jatin
if I understand you correctly, tacacs+ is not used for client wireless authentication. Am I right? I am assuming this is also applies to wired users.
Yes, I added the WLC 5508 as a radius client "RADIUS (Cisco IOS/PIX 6.0)."
This is the log that I got from the ACS:
DateTimeMessage-TypeUser-NameGroup-NameCaller-IDNetwork Access Profile NameAuthen-Failure-CodeAuthor-Failure-CodeAuthor-DataNAS-PortNAS-IP-AddressFilter InformationPEAP/EAP-FAST-Clear-NameEAP TypeEAP Type NameReasonAccess DeviceNetwork Device Group
10/28/201314:25:31Authen failedclient01@aaeng.localDefault Group44-94-fc-5b-21-19(Default)EAP_TLS Type not configured
1172.28.255.42
RK2WLC5508-01
10/28/201314:25:35Unknown NAS
(Unknown)
172.28.255.42
10/28/201314:26:26Authen failedclient01@aaeng.localDefault Group44-94-fc-5b-21-19(Default)EAP_TLS Type not configured
1172.28.255.42
RK2WLC5508-01
I am not sure how to install the CA into ACS.
~BR
Jatin Katyal
~Jatin
Thanks. The link you have provided helps me to make EAP-TLS wireless working
Wonderful. Thanks for sharing!!!
~BR
Jatin Katyal
~Jatin
I have another question regarding the passwords for my servers.
Since I joined my Windows 2003 with ACS 4.2 to the domain, my admin password for my AD/NPS and CA servers have changed to the Windows 2003 admin password.
Is this normal?
that's nothing to do with ACS joining AD (Domain). This is not a default behaviour.
~BR
Jatin Katyal
~Jatin
