09-23-2002 02:07 AM - edited 03-10-2019 07:03 AM
Hi !
I am using a Cisco ACS box combined with RSA ACE. Authentification is successful for the first time. But the router issues a callback and wants to authenticate twice. On the second attempt the tokencode is no longer valid - and callback is not successful because of the failure : RE-USE ATTACK
on the RSA ACE Server.
Why do I need a second authentification ? The call is successfully authenticated on the first time - why is there a second authentication needed ?
Thx Hans
09-27-2002 09:17 AM
You may need to configure Token Caching as shown here:
http://www.cisco.com/warp/public/129/25.html
http://www.cisco.com/warp/public/129/26.html#intro
You may also want to ask your RSA people if a similar feature is avalable in the ACE Server.
01-06-2003 03:49 AM
we are having the same problem you are describing .I see that your case is from september, did you solve it and how
thanks
guy
01-13-2003 05:48 AM
You have to instruct the router to only authenticate on dialin and not on dialout with the following command:
ppp authentication pap callin
Also, you have to mak e sure that you use PAP (instead of the default CHAP) when authenticating with RSA tokens. Hope this helps,
VS
