10-04-2014 09:38 PM - edited 03-10-2019 10:05 PM
Hi Guy,
In my ISE deployment, once the guest succcesful authenticated will be assign guest VLAN for internet access.
we are using guest portal to do the vlan override once user authenticated.
Window 7 Internet explorer (Active X), Chrome (Java Aplet) is working fine.
but Android,Apple IOS devices unable to release the DHCP and get new DHCP.
because from ISE and WLC we can see the Vlan have change, how mobile devices initiate dhcp release for Guest Portal
Kindly advice.
Freemen
10-07-2014 09:30 PM
This feature is dependent on features that are not available on mobile devices (Active X and Java). So I don't believe you will be able to get this to work on mobile devices.
Thank you for rating helpful posts!
10-07-2014 09:42 PM
Hi Neno,
Can you share me any documentation link regarding this? it will be very helpful for future reference for all people encounter same issue.
10-07-2014 10:31 PM
I don't have such documentation nor I could find any on Cisco's site. With that being said, it doesn't mean that it doesn't exist. I just know that Active X is windows specific framework and Java is not supported on either iOS nor Android:
http://www.java.com/en/download/faq/java_mobile.xml
The good news is that Cisco appears to be steering away from Java so it is possible that in the future this will be supported.
Hope this helps!
10-07-2014 10:58 PM
Neno Thanks for information
10-08-2014 06:50 AM
I don't believe that dynamic VLAN for any CWA based access is a working solution. If the user gets an IP address before policy assignment, then I just don't change VLAN.
Can you do what you're looking for by putting users in to a VLAN which they will remain (prior to CWA) and just restrict their access, then open up the access once they have passed authentication?
The need to do a DHCP refresh is then removed.
I find it hard to believe Cisco even sell dynamic VLAN as a solution for CWA (or similar). It's for sales people only.
