Cisco ISE LDAP - Error Subject <userid> is not found
Greetings Experts!
Problem:
I have configured ISE Admin Access authentication to a LDAP External Identity Store. BIND Tests to Primary and Secondary LDAP Server is successful. I have configured the major/top domain (DC=test,DC=company,DC=com) ) to see if a user id is found but is not. When I do the same BIND test (same service account credentials) using "ldp" utility in Windows 7 I can find the users under the Base DN Container as well as absolute path (
OU=Users,OU=TestDept,OU=TestEnv,DC=test,DC=company,DC=com) to the actual DN container.
Directory Organization Configuration on ISE:
Subject SearchBase DN: OU=Users,OU=TestDept,OU=TestEnv,DC=test,DC=company,DC=com
Group Search Base DN: DC=test,DC=company,DC=com
Error noticed on ISE Debug Log is:
Server,24/02/2014,08:13:38:869,WARN ,1225325456,cntx=0056723840,user=TESTUSER,LdapSubjectSearchAssistant::checkForErrors: subject TESTUSER is not found,LdapSubjectSearchAssistant.cpp:158
When tested on a Windows machine
c:\>dsquery user -name TESTUSER
"CN=TESTUSER,OU=Users,OU=TestDept,OU=TestEnv,DC=test,DC=company,DC=com"
Am I missing something here?
Thanks a lot in advance.
Srini
blenka
Level 3
Level 3
Apparently the WLC can do it fine with Local EAP:
PEAPv0/MSCHAPv2 are also supported but only if the LDAP server is set up to return a clear-text password.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0110010.html
Found the problem.
After analysing various packet captures, I noticed that ISE is placing a userPrincipalName LDAP search query for the UserID provided during Logon. When I simulated the same LDAP query using LDP utility on Windows 7, it didn't give me any results however, it did if the filter was for sAMAccountName or CN. I checked the userPrincipalName values in our Domain Controller and found that we are using <userid>@<domainname> format. I then tried to login using <userid>@<domainmain>, it worked.
Note that we do have Groups and Attribute options in LDAP Identity store but those values don't come into action unless userPrincipalName search is successful. Also, I noticed that Groups and Attributes are mainly used for Authentication Policies and to reach that point/step, we first have to get a success response for"userPrincipalName" search.
I have submitted a TAC case to see if there is any way I can place a sAMAccountName search query instead of userPrincipalName LDAP filter.
Resolution:
Under General Tab-> Use Custom Schema instead of AD Identity Source. Once you select Custom, define the ObjectClass, LDAP Search Filter etc and Thats it!
- BTW - I got this answer from TAC. :)
Hi I do have a similar problem.
I try to use LDAP to Access AD for admin authentication.
Could you please specify the working parameters?
Subject Objectclass: <AD Default=Person>
Subject Name Attribute: <AD Default=UserPrincipalName>
Group Objectclass: <AD Default=Group>
Group Map Attribute: <AD Default=memberOf>
I changed to Custom with Parameters:
Subject Objectclass: <User>
Subject Name Attribute: <sAMAccountName>
Group Objectclass: <Group>
Group Map Attribute: <memberOf>
