09-17-2014 12:13 AM - edited 03-10-2019 10:01 PM
I have a standalone ISE node, which is being stubborn about an upgrade...
The docs say this should work, but I'm getting an error...
ISE-01/admin# application upgrade ise-upgradebundle-1.1.x-to-1.2.0.899.i386.tar.gz disk
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Initiating Application Upgrade...
% Repository not found
ISE-01/admin#
09-17-2014 03:12 AM
Important Notes To Read Before You Upgrade
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/upgrade_guide/b_ise_upgrade_guide/b_ise_upgrade_guide_chapter_01.html#ID50
09-18-2014 12:31 PM
If there is any failure during the upgrade of application binaries and the Cisco ADE-OS, you should reimage and install the previous version and restore the backup.
