Cisco ISE with TACACS+ and RADIUS both?
RSundstrom
I am initiating wired authentication on an existing network using Cisco ISE. I have been studying the requirements for this. I know I have to turn on RADIUS on the Cisco switches on the network. The switches on the network are already programmed for TACACS+. Does anybody know if they can both operate on the same network at the same time?
Bob
16 Replies 16
I completely agree with Jatin Katyal.. Good one Jatin..!!!
Mohith / jatin ,
You are correct , i am having ACS running Tacacs for my network devices .
I need your help to do the switch configuration for using ISE  when i have tacacs as my default authenticaton method .
What all AAA commands are mandatory on switch for ISE to work .
Thanks in Advance
Angus
