01-01-2007 10:03 PM - edited 03-10-2019 02:53 PM
Can anybody provide me links to any good documentation on how to configure AAA Authorization using Command Shell on the ACS 4.1 ? I would be really grateful if someone one can point me few links.
Meet
01-02-2007 04:37 AM
Meet,
check out this link
http://www.cisco.com/en/US/tech/tk583/tk642/tsd_technology_support_sub-protocol_home.html
Also check out this cool attachment which was posted by Prem
HTH, rate if it does
Narayan
01-04-2007 03:06 AM
the attachment is quite worth looking.
thanks
01-03-2007 02:05 PM
I would try looking at this link:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_white_paper09186a0080088893.shtml
This describes how to plan, design and build shell cmd auth config in ACS.
Darran
01-04-2007 03:04 AM
thanks, was pretty helpful. but isnt there any document, which specifially discuss shell authorization command set. in the sense, explains and provides good examples ??
01-04-2007 04:12 AM
Not that I know of.. and the reason being that it depends totally on what you're trying to achieve.
At the end of the day a DCS is merely a list of permitted/denied commands and arguments.
The syntax is basically the same as group-level command authorisation - but the UI is java and much easier to use.
Darran
