Configuring AAA Authorization on ACS 4.1
mesmerisor
Can anybody provide me links to any good documentation on how to configure AAA Authorization using Command Shell on the ACS 4.1 ? I would be really grateful if someone one can point me few links.
Meet
5 Replies 5
royalblues
Level 10
Level 10
Meet,
check out this link
http://www.cisco.com/en/US/tech/tk583/tk642/tsd_technology_support_sub-protocol_home.html
Also check out this cool attachment which was posted by Prem
HTH, rate if it does
Narayan
the attachment is quite worth looking.
thanks
darpotter
Level 5
Level 5
I would try looking at this link:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_white_paper09186a0080088893.shtml
This describes how to plan, design and build shell cmd auth config in ACS.
Darran
thanks, was pretty helpful. but isnt there any document, which specifially discuss shell authorization command set. in the sense, explains and provides good examples ??
Not that I know of.. and the reason being that it depends totally on what you're trying to achieve.
At the end of the day a DCS is merely a list of permitted/denied commands and arguments.
The syntax is basically the same as group-level command authorisation - but the UI is java and much easier to use.
Darran
