Critical Authentication VLAN: MDA Mode
Marco Serato
Hello again
One problem is solved, but another problem has come.
I use the MDA Mode. And if the radius is not available, the voice and data device will placed in the data domain.
A security voliation blocked the port after: SECURITY_VIOLATION: Security violation on the interface FastEthernet0/1, new MAC address...
What can I do? Only the data device should placed in the critical VLAN.The voice device should not move in any vlan, when this szenario ocur.
I use IOS 12.2.(55)SE1.
Here a short excert of the configuration:
switchport mode access
switchport voice vlan 2
authentication event server dead action authorize vlan 3
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication port-control auto
dot1x pae authenticator
Thanks for any help.
Marco Serato
12 Replies 12
Tarik Admani
Marco,
A new feature which is the critical voice vlan feature is out to support this:
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_usr_8021x/configuration/15-2mt/crit-vce-vlan-supp.html
Here is the command you need to run based off the configuration guide:
authentication event server dead action authorize voice
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_55_se/configuration/guide/sw8021x.html#wp1547387
Tarik Admani
I have read this article. But the command does not work in my IOS. This command is for Cisco IOS Release 15.2M&T. I typed this command on the interface, is this right?
Authenticator(config-if)#$ion event server dead action authorize voice
authentication event server dead action authorize voice (unter vo is the '^'. It seems he doesn´t know voice )
% Invalid input detected at '^' marker.
Marco,
This is the same switch which is running 12.2(55)SE also what model switch is this?
Tarik Admani
It is a Catalyst 2960.
Marco Serato
Can you paste the show version output for me?
Tarik Admani
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 08:16 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Authenticator uptime is 2 days, 4 hours, 29 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-55.SE1.bin"
Switch Ports Model             SW Version            SW Image
*   1 26   WS-C2960-24TT-L   12.2(55)SE1           C2960-LANBASEK9-M
Marco,
I also see the same issue you are seeing and I am running 12.2(58)SE on a 2960S. Give me some time to see what I can find, if you need immediate assistance I would suggest opening a tac case and posting what the resolution steps are.
thanks,
tarik Admani
If the problem can be solved by next week, that will be fine.
  Thanks for their help.
Best regards Marco
Hello Tarik Admani, are there some new information about the problem?
Best regards Marco
Marco,
Please open a TAC case and see if an engineer can help you, either there is a bug in the documentation or there is a bug in this version of code. Once you get an answer please share with this forum.
Tarik Admani
*Please rate helpful posts*
I have not the right to open a TAC. Can you open a ticket, please?
Best regards Marco
I dont work for Cisco, so i dont have the ability to do so. However please contact your partner, or Cisco account rep so they can get you the proper support for this.
Tarik Admani
