01-06-2010 04:11 PM - edited 03-10-2019 04:52 PM
Been looking around the Cisco site to see if Cisco Secure ACS 5.1 will integrate with CSM 3.3
The best I could find this: http://www.cisco.com/en/US/products/ps6498/products_configuration_example09186a00808eada8.shtml#tabcom
Stating that CSM 3.2 works with ACS 4.2
I assume that due to the massive difference between 4.2 and 5.x that this won't integrate?
Thanks in advance,
Bruce
Solved! Go to Solution.
01-07-2010 06:49 AM
Bruce,
As mentioned in my other answer, unfortunately ACS 5.0 is not officially supported for integration with CSM 3.3. As stated in http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.3.1/release/notes/csmrn331.html AC 4.1and 4.2 are.
PK
01-07-2010 06:49 AM
Bruce,
PK
01-07-2010 03:23 PM
Hi PK,
Thanks for that,
Bruce
01-03-2011 11:10 AM
Has there been any update in the last year in regards to integrating CSM (3.3 or 4.0) and ACS 5.x? Thanks.
