Community Member
Cut Through Proxy, Logout problem with established connection
Hallo everyone,
i got a question:
i´m using a ASA 5505 with 9.1.(1), with a cut through proxy witch is working great from the inside to the outside network.
For authentication im using the XX.XXX.XXX.XX:2000/netaccess/loginuser.html.
But if i got an open connection like a static "ping" witch is running and push the logout button, the ping will still work...
It will work until i end it manuel for minimum 3s.
Is there a way to close even established connection after the logout?
71
