Design advice for AAA thru PIX
Customer need to implement AAA thru PIX,
goal is to Authentified clients from Raduis Server and also
authorized these clients to use or no some TCP ports
do i need to configure some Virtual Address on PIX in
order to achieve that ? i'm really confused how configuration
on PIX for this type of Authentication/Autorization
can somebody already worked on this type of configuration ?
thanks in advance for any help
JYP
Re: Design advice for AAA thru PIX
You need to enable authentication and authorization on the pix . Here is a good link which explains the basic confg.
http://www.cisco.com/warp/public/110/atp52.html
Sujit
Silver
The concept you are referring is called virtual http/telnet. Its not required to configured virual address under normal circumstance. This is required when you have double authentication for web server or integrade AAA server with SDI sofwtare (new pin mode etc). Pl. follow the previous post link to configure authen/autho and lets know if you have any confusion.
Mynul
140
