DHCP Snooping Trouble
Eduardo Ramirez
Hi All,
I am practicing on a home lab to attain my CCNP Switch.  My home lab is comprised of a couple of 3550 switches.  I tried to configure DHCP snooping without any luck.  I am running IOS ver. 12.2(25) SEA.  I program the feature as it states on the official certification guide along with other Cisco configs.
1.  Enable the feature globally:  S1(config)# ip dhcp snooping
2.  Define the vlan:  S1(config)# ip dhcp vlan XX
3.  Define trusted ports if any
I plug in a DHCP server and a client to two untrusted ports in the same vlan that is programmed above and they are able to connect and exchange packets without an interruption.  I am expecting the DHCP port from the DHCP server to be err-disabled due to a violation...but it is not happening.  AM I Missing something or do my switches dont work?  Any help is much appreciated.
Eddie
5 Replies 5
please post the relevant config of your switch to see if there is anything wrong. Also the output of the "sh ip dhcp snooping" command.
If possible I would also upgrade the switch to 12.2.44-SE6ED.
Thanks for replying Karsten.  Unfortunately I cannot get my hands on IOS12.2.44-SE6ED but I got C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(40)SE.  It looks like all the commands are there.  Below is my running-config.  Its just a lab, so I am just trying to get this feature to work, so it is minimally configured.
Current configuration : 2850 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname S2
no aaa new-model
ip subnet-zero
ip dhcp snooping vlan 10
ip dhcp snooping database flash:DHCPSnoopDB
ip dhcp snooping
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
 ip dhcp snooping trust
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
 switchport port-security
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
 switchport port-security maximum 500
interface FastEthernet0/12
I just put ports 1-12 in VLAN 10, connected a "trusted" DHCP server to port 1 and connected a couple of laptops to a couple other ports in VLAN 10.  I then connected a rogue dhcp server in one of the "untrusted" ports and the port did not shutdown/err-disable or increment dropped packets as per the "show ip dhcp snooping statistics detail".
Any thoughts?
The config looks fine. But if I remember right, then the violation-default is *not* to shutdown or errdisable the port. By default the offending traffic should be droppen. Look in your log for "DHCP_SNOOPING"-messages, which should have severity level 5 by default.
I did a debug on dhcp snooping packets and was not seeing any DHCP Offer messages from my "untrusted" port with rogue DHCP server.  I did a packet capture on the rogue port/dhcp server and when untrusted there was no activity on that port even if it is the only DHCP server in the segment.  I then made the port "trusted" and I was able to see active DHCP messages.  If I go see the "ip dhcp snooping stats" it does not show any dropped packets from "untrusted" ports.
I forgot the sh ip dhcp snooping output.  Here it is.  Thanks.
S2# show ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
   circuit-id format: vlan-mod-port
    remote-id format: MAC
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                    Trusted     Rate limit (pps)
FastEthernet0/1              yes         unlimited
S2#
