04-26-2003 03:45 AM - edited 03-10-2019 07:16 AM
i have problem with dialup,i have a 2600 router which has flash:c2600-i-mz.120-7.T and i am using ACS secure for authentication for our domain users.for normail dialup everything is working fine.but when i am configuring call back for some users its giving problem.
the aaa config is as follows
aaa new-model
aaa authentication login default group tacacs+
aaa authentication login no_tacacs enable
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
with above i am getting call back and getting connected but the normal users cannot able to connect and when i remove this : aaa authorization network default group tacacs+
the normal user able to connect but not the call back users.
on the async port the config is
interface Group-Async1
ip unnumbered FastEthernet0/0
no ip directed-broadcast
encapsulation ppp
ip tcp header-compression
carrier-delay msec 0
async mode interactive
peer default ip address pool default
ppp callback permit
ppp authentication pap chap
and on line it is
line 33 48
autoselect during-login
autoselect ppp
script callback callback
modem InOut
modem autoconfigure discovery
transport input all
stopbits 1
flowcontrol hardware
group-range 33 48
i am getting the following i debug it....
6w3d: AAA/AUTHOR/FSM: As33 (19809119) user='dial'
6w3d: As33 AAA/AUTHOR/FSM (19809119): send AV service=ppp
6w3d: As33 AAA/AUTHOR/FSM (19809119): send AV protocol=ip
6w3d: As33 AAA/AUTHOR/FSM (19809119): found list "default"
6w3d: As33 AAA/AUTHOR/FSM (19809119): Method=tacacs+ (tacacs+)
6w3d: AAA/AUTHOR/TAC+: (19809119): user=dial
6w3d: AAA/AUTHOR/TAC+: (19809119): send AV service=ppp
6w3d: AAA/AUTHOR/TAC+: (19809119): send AV protocol=ip
6w3d: TAC+: (19809119): received author response status = PASS_ADD
6w3d: As33 AAA/AUTHOR (19809119): Post authorization status = PASS_ADD
6w3d: As33 AAA/AUTHOR/FSM: We can start IPCP
6w3d: As33 IPCP: O CONFREQ [Closed] id 20 len 10
6w3d: As33 IPCP: Address 129.6.2.205 (0x0306810602CD)
6w3d: As33 AAA/AUTHOR/FSM: (0): Can we start CCP?
6w3d: As33 AAA/AUTHOR/FSM (2476690859): Port='Async33' list='' service=NET
6w3d: AAA/AUTHOR/FSM: As33 (2476690859) user='dial'
6w3d: As33 AAA/AUTHOR/FSM (2476690859): send AV service=ppp
6w3d: As33 AAA/AUTHOR/FSM (2476690859): send AV protocol=ccp
6w3d: As33 AAA/AUTHOR/FSM (2476690859): found list "default"
6w3d: As33 AAA/AUTHOR/FSM (2476690859): Method=tacacs+ (tacacs+)
6w3d: AAA/AUTHOR/TAC+: (2476690859): user=dial
6w3d: AAA/AUTHOR/TAC+: (2476690859): send AV service=ppp
6w3d: AAA/AUTHOR/TAC+: (2476690859): send AV protocol=ccp
6w3d: TAC+: (2476690859): received author response status = FAIL
6w3d: As33 AAA/AUTHOR (2476690859): Post authorization status = FAIL
6w3d: As33 AAA/AUTHOR/FSM: We cannot start CCP
6w3d: As33 CCP: State is Closed
6w3d: As33 AAA/AUTHOR/FSM: (0): Can we start CDPCP?
6w3d: As33 AAA/AUTHOR/FSM (391693916): Port='Async33' list='' service=NET
6w3d: AAA/AUTHOR/FSM: As33 (391693916) user='dial'
6w3d: As33 AAA/AUTHOR/FSM (391693916): send AV service=ppp
6w3d: As33 AAA/AUTHOR/FSM (391693916): send AV protocol=cdp
6w3d: As33 AAA/AUTHOR/FSM (391693916): found list "default"
6w3d: As33 AAA/AUTHOR/FSM (391693916): Method=tacacs+ (tacacs+)
6w3d: AAA/AUTHOR/TAC+: (391693916): user=dial
6w3d: AAA/AUTHOR/TAC+: (391693916): send AV service=ppp
6w3d: AAA/AUTHOR/TAC+: (391693916): send AV protocol=cdp
6w3d: TAC+: (391693916): received author response status = FAIL
6w3d: As33 AAA/AUTHOR (391693916): Post authorization status = FAIL
6w3d: As33 AAA/AUTHOR/FSM: We cannot start CDPCP
6w3d: As33 CDPCP: State is Closed
please suggest your comments.....
04-26-2003 04:37 PM
Here is the best url which discuss exactly that
http://www.cisco.com/warp/public/480/pppcallback_tac.html
Looks to me that the "non callback" users are failing the authorization. So
Try to use command "aaa authorization network default group tacacs+ local". With this command things should be fine. Otherwise needs to see the debug as mentioned under the "debug commands" on that url for the "non-callback" users.
04-26-2003 10:51 PM
it is the same i tried using the "aaa authorization network default group tacacs+ local" for both callback and non calback users it giving the same debug if i use it and if i remove it the non callback users connecting successfully but not callback users.
below the debug
6w6d: AAA: parse name=tty33 idb type=10 tty=33
6w6d: AAA: name=tty33 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=33 channel
=0
6w6d: AAA/MEMORY: create_user (0x80E3ADDC) user='' ruser='' port='tty33' rem_add
r='async' authen_type=ASCII service=LOGIN priv=1
6w6d: AAA/MEMORY: free_user (0x80E3ADDC) user='' ruser='' port='tty33' rem_addr=
6w6d: %LINK-3-UPDOWN: Interface Async33, changed state to up
6w6d: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
6w6d: AAA: parse name=Async33 idb type=10 tty=33
6w6d: AAA: name=Async33 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=33 chann
el=0
6w6d: AAA/MEMORY: create_user (0x80E032EC) user='dial' ruser='' port='Async33' r
em_addr='async' authen_type=PAP service=PPP priv=1
6w6d: As33 AAA/AUTHOR/LCP: Authorize LCP
6w6d: As33 AAA/AUTHOR/LCP (4202832239): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/LCP: As33 (4202832239) user='dial'
6w6d: As33 AAA/AUTHOR/LCP (4202832239): send AV service=ppp
6w6d: As33 AAA/AUTHOR/LCP (4202832239): send AV protocol=lcp
6w6d: As33 AAA/AUTHOR/LCP (4202832239): found list "default"
6w6d: As33 AAA/AUTHOR/LCP (4202832239): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (4202832239): user=dial
6w6d: AAA/AUTHOR/TAC+: (4202832239): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (4202832239): send AV protocol=lcp
6w6d: As33 AAA/AUTHOR (4202832239): Post authorization status = PASS_ADD
6w6d: As33 AAA/AUTHOR/FSM: (0): Can we start IPCP?
6w6d: As33 AAA/AUTHOR/FSM (1621430573): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (1621430573) user='dial'
6w6d: As33 AAA/AUTHOR/FSM (1621430573): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (1621430573): send AV protocol=ip
6w6d: As33 AAA/AUTHOR/FSM (1621430573): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (1621430573): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (1621430573): user=dial
6w6d: AAA/AUTHOR/TAC+: (1621430573): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (1621430573): send AV protocol=ip
6w6d: As33 AAA/AUTHOR (1621430573): Post authorization status = PASS_ADD
6w6d: As33 AAA/AUTHOR/FSM: (0): Can we start CCP?
6w6d: As33 AAA/AUTHOR/FSM (4266979043): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (4266979043) user='dial'
6w6d: As33 AAA/AUTHOR/FSM (4266979043): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (4266979043): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (4266979043): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (4266979043): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (4266979043): user=dial
6w6d: AAA/AUTHOR/TAC+: (4266979043): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (4266979043): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR (4266979043): Post authorization status = FAIL
6w6d: As33 AAA/AUTHOR/FSM: We cannot start CCP
6w6d: As33 AAA/AUTHOR/FSM (2762734403): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (2762734403) user='dial'
6w6d: As33 AAA/AUTHOR/FSM (2762734403): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (2762734403): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (2762734403): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (2762734403): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (2762734403): user=dial
6w6d: AAA/AUTHOR/TAC+: (2762734403): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (2762734403): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR (2762734403): Post authorization status = FAIL
6w6d: As33 AAA/AUTHOR/FSM (1118144410): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (1118144410) user='dial'
6w6d: As33 AAA/AUTHOR/FSM (1118144410): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (1118144410): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (1118144410): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (1118144410): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (1118144410): user=dial
6w6d: AAA/AUTHOR/TAC+: (1118144410): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (1118144410): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR (1118144410): Post authorization status = FAIL
looking for your suggestion
04-26-2003 11:18 PM
this for callback
CALLBACK ----------------------------------------------------------
=0
6w6d: AAA/MEMORY: create_user (0x80E2E4E4) user='' ruser='' port='tty33' rem_add
6w6d: AAA/AUTHEN/START (457313309): port='tty33' list='' action=LOGIN service=LO
GIN
6w6d: AAA/AUTHEN/START (457313309): using "default" list
6w6d: AAA/AUTHEN/START (457313309): Method=tacacs+ (tacacs+)
6w6d: TAC+: send AUTHEN/START packet ver=192 id=457313309
6w6d: TAC+: ver=192 id=457313309 received AUTHEN status = GETUSER
6w6d: AAA/AUTHEN (457313309): status = GETUSER
6w6d: AAA/AUTHEN/ABORT: (457313309) because Autoselected.
6w6d: TAC+: send abort reason=Autoselected
6w6d: AAA/MEMORY: free_user (0x80E2E4E4) user='' ruser='' port='tty33' rem_addr=
6w6d: As33 PPP: Treating connection as a dedicated line
6w6d: As33 PAP: I AUTH-REQ id 59 len 17 from "call"
6w6d: As33 PAP: Authenticating peer call
el=0
6w6d: AAA/MEMORY: create_user (0x80E3ADDC) user='call' ruser='' port='Async33' r
6w6d: AAA/AUTHEN/START (3070821037): port='Async33' list='' action=LOGIN service
=PPP
6w6d: AAA/AUTHEN/START (3070821037): using "default" list
6w6d: AAA/AUTHEN/START (3070821037): Method=tacacs+ (tacacs+)
6w6d: TAC+: send AUTHEN/START packet ver=193 id=3070821037
6w6d: TAC+: ver=193 id=3070821037 received AUTHEN status = PASS
6w6d: AAA/AUTHEN (3070821037): status = PASS
6w6d: As33 AAA/AUTHOR/LCP (4128991479): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/LCP: As33 (4128991479) user='call'
6w6d: As33 AAA/AUTHOR/LCP (4128991479): send AV service=ppp
6w6d: As33 AAA/AUTHOR/LCP (4128991479): send AV protocol=lcp
6w6d: As33 AAA/AUTHOR/LCP (4128991479): found list "default"
6w6d: As33 AAA/AUTHOR/LCP (4128991479): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (4128991479): user=call
6w6d: AAA/AUTHOR/TAC+: (4128991479): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (4128991479): send AV protocol=lcp
6w6d: TAC+: (4128991479): received author response status = PASS_ADD
6w6d: As33 AAA/AUTHOR (4128991479): Post authorization status = PASS_ADD
6w6d: As33 AAA/AUTHOR/LCP: Processing AV service=ppp
6w6d: As33 AAA/AUTHOR/LCP: Processing AV protocol=lcp
6w6d: As33 AAA/AUTHOR/LCP: Processing AV callback-dialstring=
6w6d: As33 PAP: O AUTH-ACK id 59 len 5
6w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async33, changed state to
up
down
6w6d: %LINK-5-CHANGED: Interface Async33, changed state to reset
6w6d: AAA/MEMORY: free_user (0x80E3ADDC) user='call' ruser='' port='Async33' rem
6w6d: %LINK-3-UPDOWN: Interface Async33, changed state to down
6w6d: As33 PAP: I AUTH-REQ id 60 len 17 from "call"
el=0
6w6d: AAA/AUTHEN/START (3997176954): port='Async33' list='' action=LOGIN service
=PPP
6w6d: AAA/AUTHEN/START (3997176954): using "default" list
6w6d: AAA/AUTHEN/START (3997176954): Method=tacacs+ (tacacs+)
6w6d: TAC+: send AUTHEN/START packet ver=193 id=3997176954
6w6d: TAC+: ver=193 id=3997176954 received AUTHEN status = PASS
6w6d: AAA/AUTHEN (3997176954): status = PASS
6w6d: As33 AAA/AUTHOR/LCP (424355650): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/LCP: As33 (424355650) user='call'
6w6d: As33 AAA/AUTHOR/LCP (424355650): send AV service=ppp
6w6d: As33 AAA/AUTHOR/LCP (424355650): send AV protocol=lcp
6w6d: As33 AAA/AUTHOR/LCP (424355650): found list "default"
6w6d: As33 AAA/AUTHOR/LCP (424355650): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (424355650): user=call
6w6d: AAA/AUTHOR/TAC+: (424355650): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (424355650): send AV protocol=lcp
6w6d: TAC+: (424355650): received author response status = PASS_ADD
6w6d: As33 AAA/AUTHOR (424355650): Post authorization status = PASS_ADD
6w6d: As33 PAP: O AUTH-ACK id 60 len 5
6w6d: As33 AAA/AUTHOR/FSM (3677461016): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (3677461016) user='call'
6w6d: As33 AAA/AUTHOR/FSM (3677461016): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (3677461016): send AV protocol=ip
6w6d: As33 AAA/AUTHOR/FSM (3677461016): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (3677461016): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (3677461016): user=call
6w6d: AAA/AUTHOR/TAC+: (3677461016): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (3677461016): send AV protocol=ip
6w6d: TAC+: (3677461016): received author response status = PASS_ADD
6w6d: As33 AAA/AUTHOR (3677461016): Post authorization status = PASS_ADD
6w6d: As33 AAA/AUTHOR/FSM: We can start IPCP
6w6d: As33 AAA/AUTHOR/FSM (3725013142): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (3725013142) user='call'
6w6d: As33 AAA/AUTHOR/FSM (3725013142): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (3725013142): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (3725013142): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (3725013142): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (3725013142): user=call
6w6d: AAA/AUTHOR/TAC+: (3725013142): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (3725013142): send AV protocol=ccp
6w6d: TAC+: (3725013142): received author response status = FAIL
6w6d: As33 AAA/AUTHOR (3725013142): Post authorization status = FAIL
up
6w6d: As33 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 129.6.6.168
6w6d: As33 AAA/AUTHOR/IPCP: Says use pool 129.6.2.205
el=0
6w6d: AAA/MEMORY: create_user (0x80E38B60) user='pools-RAS01' ruser='' port
='Async33' rem_addr='async' authen_type=NONE service=NONE priv=1
6w6d: As33 AAA/AUTHOR/POOL (58533224): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/POOL: As33 (58533224) user='pools-RAS01'
6w6d: As33 AAA/AUTHOR/POOL (58533224): send AV service=ppp
6w6d: As33 AAA/AUTHOR/POOL (58533224): send AV protocol=ip
6w6d: Async33 AAA/AUTHOR/POOL (58533224): found list "default"
6w6d: As33 AAA/AUTHOR/POOL (58533224): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (58533224): user=pools-RAS01
6w6d: AAA/AUTHOR/TAC+: (58533224): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (58533224): send AV protocol=ip
6w6d: TAC+: (58533224): received author response status = FAIL
6w6d: AAA/AUTHOR (58533224): Post authorization status = FAIL
6w6d: AAA/MEMORY: free_user (0x80E38B60) user='pools-RAS01' ruser='' port='
6w6d: As33 AAA/AUTHOR/IPCP: Cannot satisfy pool request
6w6d: As33 AAA/AUTHOR/FSM (2660630301): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (2660630301) user='call'
6w6d: As33 AAA/AUTHOR/FSM (2660630301): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (2660630301): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (2660630301): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (2660630301): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (2660630301): user=call
6w6d: AAA/AUTHOR/TAC+: (2660630301): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (2660630301): send AV protocol=ccp
6w6d: TAC+: (2660630301): received author response status = FAIL
6w6d: As33 AAA/AUTHOR (2660630301): Post authorization status = FAIL
6w6d: As33 AAA/AUTHOR/FSM (3693302461): Port='Async33' list='' service=NET
6w6d: AAA/AUTHOR/FSM: As33 (3693302461) user='call'
6w6d: As33 AAA/AUTHOR/FSM (3693302461): send AV service=ppp
6w6d: As33 AAA/AUTHOR/FSM (3693302461): send AV protocol=ccp
6w6d: As33 AAA/AUTHOR/FSM (3693302461): found list "default"
6w6d: As33 AAA/AUTHOR/FSM (3693302461): Method=tacacs+ (tacacs+)
6w6d: AAA/AUTHOR/TAC+: (3693302461): user=call
6w6d: AAA/AUTHOR/TAC+: (3693302461): send AV service=ppp
6w6d: AAA/AUTHOR/TAC+: (3693302461): send AV protocol=ccp
6w6d: TAC+: (3693302461): received author response status = FAIL
6w6d: As33 AAA/AUTHOR (3693302461): Post authorization status = FAIL
down
04-27-2003 01:54 PM
I think you haven't turned on the debug for "debug ppp negotiation" for a failed call.
Leave that "aaa authorization ...." in the config and turned on the debug for following for a failed call.
debug aaa authentication
debug aaa authorization
debug aaa per
Also where dose that CCP coming from? Do you need it?
04-27-2003 09:10 PM
here is debug with debug aaa authentication,debug aaa authorization,debug ppp negotiation,debug aaa per and "aaa autho network..... "i dont know where from this ccp coming and i dont need it.i just want to have callback and non callback to work together.its not giving callback unless i put "aaa autho net..."
i am pasting the debug in two post bcoz its not coming in ont post.
7w0d: AAA: parse name=tty33 idb type=10 tty=33
7w0d: AAA: name=tty33 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=33 channel
=0
7w0d: AAA/MEMORY: create_user (0x80DF96A4) user='' ruser='' port='tty33' rem_add
7w0d: AAA/AUTHEN/START (3027969203): port='tty33' list='' action=LOGIN service=L
OGIN
7w0d: AAA/AUTHEN/START (3027969203): using "default" list
7w0d: AAA/AUTHEN/START (3027969203): Method=tacacs+ (tacacs+)
7w0d: TAC+: send AUTHEN/START packet ver=192 id=3027969203
7w0d: TAC+: ver=192 id=3027969203 received AUTHEN status = GETUSER
7w0d: AAA/AUTHEN (3027969203): status = GETUSER
7w0d: AAA/AUTHEN/ABORT: (3027969203) because Autoselected.
7w0d: TAC+: send abort reason=Autoselected
7w0d: AAA/MEMORY: free_user (0x80DF96A4) user='' ruser='' port='tty33' rem_addr=
7w0d: %LINK-3-UPDOWN: Interface Async33, changed state to up
7w0d: As33 PPP: Treating connection as a dedicated line
7w0d: As33 PPP: Phase is ESTABLISHING, Active Open
7w0d: As33 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
7w0d: As33 LCP: O CONFREQ [Closed] id 216 len 24
7w0d: As33 LCP: ACCM 0x000A0000 (0x0206000A0000)
7w0d: As33 LCP: AuthProto PAP (0x0304C023)
7w0d: As33 LCP: MagicNumber 0x03E5C12C (0x050603E5C12C)
7w0d: As33 LCP: PFC (0x0702)
7w0d: As33 LCP: ACFC (0x0802)
7w0d: As33 LCP: I CONFACK [REQsent] id 216 len 24
7w0d: As33 LCP: TIMEout: State ACKrcvd
7w0d: As33 LCP: O CONFREQ [ACKrcvd] id 217 len 24
7w0d: As33 LCP: I CONFACK [REQsent] id 217 len 24
7w0d: As33 LCP: I CONFREQ [ACKrcvd] id 2 len 50
7w0d: As33 LCP: ACCM 0x00000000 (0x020600000000)
7w0d: As33 LCP: MagicNumber 0x44F42279 (0x050644F42279)
7w0d: As33 LCP: Callback 6 (0x0D0306)
7w0d: As33 LCP: MRRU 1614 (0x1104064E)
7w0d: As33 LCP: EndpointDisc 1 Local
7w0d: As33 LCP: (0x131701F77B93A4FEDC410FBF91BBCF30)
7w0d: As33 LCP: (0x07396B00000000)
7w0d: As33 LCP: O CONFREJ [ACKrcvd] id 2 len 31
7w0d: As33 LCP: I CONFREQ [ACKrcvd] id 3 len 23
7w0d: As33 LCP: O CONFACK [ACKrcvd] id 3 len 23
7w0d: As33 LCP: State is Open
7w0d: As33 PPP: Phase is AUTHENTICATING, by this end
7w0d: As33 LCP: I IDENTIFY [Open] id 4 len 18 magic 0x44F42279 MSRASV5.00
7w0d: As33 LCP: I IDENTIFY [Open] id 5 len 22 magic 0x44F42279 MSRAS-1-NAYEEM
7w0d: As33 PAP: I AUTH-REQ id 75 len 17 from "call"
7w0d: As33 PAP: Authenticating peer call
7w0d: AAA: parse name=Async33 idb type=10 tty=33
7w0d: AAA: name=Async33 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=33 chann
el=0
7w0d: AAA/MEMORY: create_user (0x80DF96A4) user='call' ruser='' port='Async33' r
7w0d: AAA/AUTHEN/START (1737417160): port='Async33' list='' action=LOGIN service
=PPP
7w0d: AAA/AUTHEN/START (1737417160): using "default" list
7w0d: AAA/AUTHEN/START (1737417160): Method=tacacs+ (tacacs+)
7w0d: TAC+: send AUTHEN/START packet ver=193 id=1737417160
7w0d: TAC+: ver=193 id=1737417160 received AUTHEN status = PASS
7w0d: AAA/AUTHEN (1737417160): status = PASS
7w0d: As33 AAA/AUTHOR/LCP: Authorize LCP
7w0d: As33 AAA/AUTHOR/LCP (984675181): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/LCP: As33 (984675181) user='call'
7w0d: As33 AAA/AUTHOR/LCP (984675181): send AV service=ppp
7w0d: As33 AAA/AUTHOR/LCP (984675181): send AV protocol=lcp
7w0d: As33 AAA/AUTHOR/LCP (984675181): found list "default"
7w0d: As33 AAA/AUTHOR/LCP (984675181): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (984675181): user=call
7w0d: AAA/AUTHOR/TAC+: (984675181): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (984675181): send AV protocol=lcp
7w0d: TAC+: (984675181): received author response status = PASS_ADD
7w0d: As33 AAA/AUTHOR (984675181): Post authorization status = PASS_ADD
7w0d: As33 AAA/AUTHOR/LCP: Processing AV service=ppp
7w0d: As33 AAA/AUTHOR/LCP: Processing AV protocol=lcp
7w0d: As33 AAA/AUTHOR/LCP: Processing AV callback-dialstring=
7w0d: As33 PAP: O AUTH-ACK id 75 len 5
7w0d: As33 MCB: User call Callback Number - Client ANY
7w0d: Async33 PPP: O MCB Request(1) id 144 len 11
7w0d: Async33 MCB: O 1 90 0 B 1 2 2 5 0 1 0
7w0d: As33 MCB: O Request Id 144 Callback Type Client-Num delay 0
7w0d: As33 PPP: Phase is CBCP
7w0d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async33, changed state to
up
7w0d: Async33 PPP: I MCB Response(2) id 144 len 18
7w0d: Async33 MCB: I 2 90 0 12 2 E C 1 30 2C 33 34 35 32 36 39
35 0
7w0d: As33 MCB: Received response
7w0d: As33 MCB: Response CBK-Client-Num 2 14 12, addr 1-0,3452695
7w0d: Async33 PPP: O MCB Ack(3) id 145 len 18
7w0d: Async33 MCB: O 3 91 0 12 2 E C 1 30 2C 33 34 35 32 36 39
35 0
7w0d: As33 MCB: O Ack Id 145 Callback Type Client-Num delay 12
7w0d: As33 MCB: Negotiated MCB with peer
7w0d: As33 LCP: I TERMREQ [Open] id 6 len 16 (0x44F42279003CCD7400000000)
7w0d: As33 LCP: O TERMACK [Open] id 6 len 4
7w0d: As33 MCB: Peer terminating the link
7w0d: As33 MCB: Link terminated by peer, Callback Needed
7w0d: As33 MCB: Initiate Callback for call at 0,3452695 using Async
7w0d: As33 MCB: Async-callback in progress
7w0d: As33 PPP: Phase is TERMINATING
7w0d: As33 AAA/AUTHOR/PER-USER: Event LCP_DOWN
7w0d: As33 AAA/AUTHOR: LCP_DOWN
down
7w0d: %LINK-5-CHANGED: Interface Async33, changed state to reset
7w0d: As33 LCP: State is Closed
7w0d: As33 PPP: Phase is DOWN
7w0d: AAA/MEMORY: free_user (0x80DF96A4) user='call' ruser='' port='Async33' rem
7w0d: As33 IPCP: Remove route to 129.6.6.170
7w0d: %LINK-3-UPDOWN: Interface Async33, changed state to down
7w0d: As33 LCP: I CONFREQ [Closed] id 0 len 47
7w0d: As33 LCP: MagicNumber 0x17E773C2 (0x050617E773C2)
7w0d: As33 LCP: Lower layer not up, Fast Starting
7w0d: As33 LCP: O CONFREQ [Closed] id 218 len 24
7w0d: As33 LCP: MagicNumber 0x03E66DAA (0x050603E66DAA)
7w0d: As33 LCP: O CONFREJ [REQsent] id 0 len 31
7w0d: As33 LCP: I CONFACK [REQsent] id 218 len 24
7w0d: As33 LCP: I CONFREQ [ACKrcvd] id 1 len 20
7w0d: As33 LCP: O CONFACK [ACKrcvd] id 1 len 20
7w0d: As33 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x17E773C2 MSRASV5.00
to be continued....
04-27-2003 09:16 PM
the continuation......
7w0d: As33 LCP: I IDENTIFY [Open] id 3 len 22 magic 0x17E773C2 MSRAS-1-xyz123
7w0d: As33 PAP: I AUTH-REQ id 76 len 17 from "call"
el=0
7w0d: AAA/AUTHEN/START (1313656727): port='Async33' list='' action=LOGIN service
=PPP
7w0d: AAA/AUTHEN/START (1313656727): using "default" list
7w0d: AAA/AUTHEN/START (1313656727): Method=tacacs+ (tacacs+)
7w0d: TAC+: send AUTHEN/START packet ver=193 id=1313656727
7w0d: TAC+: ver=193 id=1313656727 received AUTHEN status = PASS
7w0d: AAA/AUTHEN (1313656727): status = PASS
7w0d: As33 AAA/AUTHOR/LCP (3847832388): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/LCP: As33 (3847832388) user='call'
7w0d: As33 AAA/AUTHOR/LCP (3847832388): send AV service=ppp
7w0d: As33 AAA/AUTHOR/LCP (3847832388): send AV protocol=lcp
7w0d: As33 AAA/AUTHOR/LCP (3847832388): found list "default"
7w0d: As33 AAA/AUTHOR/LCP (3847832388): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (3847832388): user=call
7w0d: AAA/AUTHOR/TAC+: (3847832388): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (3847832388): send AV protocol=lcp
7w0d: TAC+: (3847832388): received author response status = PASS_ADD
7w0d: As33 AAA/AUTHOR (3847832388): Post authorization status = PASS_ADD
7w0d: As33 PAP: O AUTH-ACK id 76 len 5
7w0d: As33 PPP: Phase is UP
7w0d: As33 AAA/AUTHOR/FSM: (0): Can we start IPCP?
7w0d: As33 AAA/AUTHOR/FSM (3051466932): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/FSM: As33 (3051466932) user='call'
7w0d: As33 AAA/AUTHOR/FSM (3051466932): send AV service=ppp
7w0d: As33 AAA/AUTHOR/FSM (3051466932): send AV protocol=ip
7w0d: As33 AAA/AUTHOR/FSM (3051466932): found list "default"
7w0d: As33 AAA/AUTHOR/FSM (3051466932): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (3051466932): user=call
7w0d: AAA/AUTHOR/TAC+: (3051466932): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (3051466932): send AV protocol=ip
7w0d: As33 CCP: I CONFREQ [Closed] id 4 len 10
7w0d: As33 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
7w0d: As33 CCP: Lower layer not up, discarding packet
7w0d: As33 IPCP: I CONFREQ [Closed] id 5 len 40
7w0d: As33 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
7w0d: As33 IPCP: Address 0.0.0.0 (0x030600000000)
7w0d: As33 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
7w0d: As33 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
7w0d: As33 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
7w0d: As33 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
7w0d: TAC+: (3051466932): received author response status = PASS_ADD
7w0d: As33 AAA/AUTHOR (3051466932): Post authorization status = PASS_ADD
7w0d: As33 AAA/AUTHOR/FSM: We can start IPCP
7w0d: As33 IPCP: O CONFREQ [Closed] id 59 len 10
7w0d: As33 IPCP: Address 129.6.2.205 (0x0306810602CD)
7w0d: As33 AAA/AUTHOR/FSM: (0): Can we start CCP?
7w0d: As33 AAA/AUTHOR/FSM (1838479872): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/FSM: As33 (1838479872) user='call'
7w0d: As33 AAA/AUTHOR/FSM (1838479872): send AV service=ppp
7w0d: As33 AAA/AUTHOR/FSM (1838479872): send AV protocol=ccp
7w0d: As33 AAA/AUTHOR/FSM (1838479872): found list "default"
7w0d: As33 AAA/AUTHOR/FSM (1838479872): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (1838479872): user=call
7w0d: AAA/AUTHOR/TAC+: (1838479872): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (1838479872): send AV protocol=ccp
7w0d: As33 IPCP: I CONFACK [REQsent] id 59 len 10
7w0d: TAC+: (1838479872): received author response status = FAIL
7w0d: As33 AAA/AUTHOR (1838479872): Post authorization status = FAIL
7w0d: As33 AAA/AUTHOR/FSM: We cannot start CCP
7w0d: As33 CCP: State is Closed
7w0d: As33 AAA/AUTHOR/FSM: (0): Can we start CDPCP?
7w0d: As33 AAA/AUTHOR/FSM (740497526): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/FSM: As33 (740497526) user='call'
7w0d: As33 AAA/AUTHOR/FSM (740497526): send AV service=ppp
7w0d: As33 AAA/AUTHOR/FSM (740497526): send AV protocol=cdp
7w0d: As33 AAA/AUTHOR/FSM (740497526): found list "default"
7w0d: As33 AAA/AUTHOR/FSM (740497526): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (740497526): user=call
7w0d: AAA/AUTHOR/TAC+: (740497526): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (740497526): send AV protocol=cdp
7w0d: TAC+: (740497526): received author response status = FAIL
7w0d: As33 AAA/AUTHOR (740497526): Post authorization status = FAIL
7w0d: As33 AAA/AUTHOR/FSM: We cannot start CDPCP
7w0d: As33 CDPCP: State is Closed
up
7w0d: As33 PPP: Outbound cdp packet dropped, CDPCP is Closed [starting negotiati
ons]
ons]
ons]
7w0d: As33 CDPCP: TIMEout: State Closed
7w0d: As33 CDPCP: State is Listen
7w0d: As33 IPCP: I CONFREQ [ACKrcvd] id 6 len 40
7w0d: As33 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 129.6.6.170
7w0d: As33 AAA/AUTHOR/IPCP: Says use pool 129.6.2.205
el=0
7w0d: AAA/MEMORY: create_user (0x80E41DBC) user='pools-RAS01' ruser='' port
7w0d: As33 AAA/AUTHOR/POOL (1344099588): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/POOL: As33 (1344099588) user='pools-RAS01'
7w0d: As33 AAA/AUTHOR/POOL (1344099588): send AV service=ppp
7w0d: As33 AAA/AUTHOR/POOL (1344099588): send AV protocol=ip
7w0d: Async33 AAA/AUTHOR/POOL (1344099588): found list "default"
7w0d: As33 AAA/AUTHOR/POOL (1344099588): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (1344099588): user=pools-RAS01
7w0d: AAA/AUTHOR/TAC+: (1344099588): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (1344099588): send AV protocol=ip
7w0d: TAC+: (1344099588): received author response status = FAIL
7w0d: AAA/AUTHOR (1344099588): Post authorization status = FAIL
7w0d: AAA/MEMORY: free_user (0x80E41DBC) user='pools-RAS01' ruser='' port='
7w0d: As33 AAA/AUTHOR/IPCP: Cannot satisfy pool request
7w0d: As33 LCP: O PROTREJ [Open] id 219 len 46 protocol IPCP
7w0d: As33 LCP: (0x8021010600280206002D0F0103060000)
7w0d: As33 LCP: (0x00008106000000008206000000008306)
7w0d: As33 LCP: (0x00000000840600000000)
7w0d: As33 IPCP: State is Closed
7w0d: As33 CCP: I CONFREQ [Closed] id 7 len 10
7w0d: As33 CCP: I CONFREQ [Listen] id 8 len 10
7w0d: As33 AAA/AUTHOR/FSM (2606674676): Port='Async33' list='' service=NET
7w0d: AAA/AUTHOR/FSM: As33 (2606674676) user='call'
7w0d: As33 AAA/AUTHOR/FSM (2606674676): send AV service=ppp
7w0d: As33 AAA/AUTHOR/FSM (2606674676): send AV protocol=ccp
7w0d: As33 AAA/AUTHOR/FSM (2606674676): found list "default"
7w0d: As33 AAA/AUTHOR/FSM (2606674676): Method=tacacs+ (tacacs+)
7w0d: AAA/AUTHOR/TAC+: (2606674676): user=call
7w0d: AAA/AUTHOR/TAC+: (2606674676): send AV service=ppp
7w0d: AAA/AUTHOR/TAC+: (2606674676): send AV protocol=ccp
7w0d: TAC+: (2606674676): received author response status = FAIL
7w0d: As33 AAA/AUTHOR (2606674676): Post authorization status = FAIL
7w0d: As33 LCP: I TERMREQ [Open] id 9 len 16 (0x17E773C2003CCD7400000000)
7w0d: As33 LCP: O TERMACK [Open] id 9 len 4
down
one more thing ,when i try to put "(config)#aaa authorization network tacacs+"
it give me this "7w0d: AAA/AUTHOR: config command authorization not enabled "
is it a bug in IOS ,i have flash:c2600-i-mz.120-7.T
looking for your suggestions...
04-27-2003 09:26 PM
i think i put the command in wrong way its accepting this config)#aaa authorization network tacacs+" command but still the same problem.
i just wana know for callback and non callback this aaa autho net should be there or not.if not,when i remove it and try callback it not working only noncallback is working.
suggest me please.
05-02-2003 10:01 PM
tepatel please suggest me what should be my next step
05-03-2003 09:13 AM
Its stil fialing with the compression again, try to add "compress mppc" under the "interface group-async 1" and see the results.
If that still dosen't work, i would suggest to open a tac case on that issue by logging at www.cisco.com/tac
