direct enable mode acess with the Help of ACS
jain.nitin
Level 3
Level 3
Dear All, I am trying to setup a group which has priv 15 access & they should see enable mode after authentication via ACS, they should not be asked for enable password. How ca I do this, I am unable to do so. I tried it but its not working. What I need is ACS should assign priv level 15 to configured users. I dont want to use Shell commands set.
Same thing I need for ASA firewall as well..
Is there any way to achive this.
Jagdeep Gambhir
Level 10
Level 10
For IOS devices,
Router(config)# username [username] password [password]
tacacs-server host [ip]
tacacs-server key [key]
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ if-authenticated
On ACS
Bring users/groups in at level 15
1. Go to user or group setup in ACS
2. Drop down to "TACACS+ Settings"
3. Place a check in "Shell (Exec)"
4. Place a check in "Privilege level" and enter "15" in the adjacent field
This feature is not supported on ASA/firewalls.
~JG
Do rate helpful posts
I tried this but it didnt work for me see my config below on deivces
aaa new-model
aaa group server tacacs+ bwaaa
server 10.2.6.1
server 10.2.6.2
ip tacacs source-interface Vlan1111
aaa authentication login aaa-list group bwaaa local
aaa authentication enable default group bwaaa enable
aaa authorization exec aaa-list group bwaaa local
aaa accounting exec aaa-list start-stop group bwaaa
aaa accounting commands 1 aaa-list start-stop group bwaaa
aaa accounting commands 15 aaa-list start-stop group bwaaa
aaa accounting system default start-stop group bwaaa
First try with simple vanilla config
aaa new-model
If still issue is there get the debugs then
debug aaa authentication
debug aaa authorization
debug tacacs
~JG
Hi, Thanks it worlked with default list but it is not working with my defined list..I dont know whats the reason behind that..do you have any idea
