Dot1x port authentication configuration
Hello Friends,
I am working on dot1x configuration deployment project and wanted to clear one confusion, I am having simple setup in which after authentication, workstation should go to vlan decided by ACS and after failed authenticatio, workstation should go to Guest or auth-fail any one is fine since I will keep both same.
So I can understand that basic config should be as follows considering old IOS.
int fas0/1
dot1x port-control auto
switchport mode access
switchport guest-vlan 10
switchport auth-fail valn 10
Now I had see many configuration examples and found that many have defined vlan's in switchport mode access [5]
Why is this command needed since vlan will be assigned from ACS, Could somone tell me why few configuration have defind ports in some vlans already ?
Also what can be best practice in case ACS server goes down, since in that scenario all workstation will fail into auth-fail or Guest vlan's.
Is there any Best practices for such scenario's ?????
Ajay
347
