01-01-2003 02:16 PM - edited 03-10-2019 07:05 AM
I'm trying to config a 12.0(5.1)XP 2900XL IOS switch to automatically go into enable mode once authenticated, without having to enter "enable." I'm running ACS3.1. Her is the AAA config:
aaa new-model
aaa authentication login default group tacacs+ local-case
aaa authentication login LOCAL local-case none
aaa authentication enable default group tacacs+ enable
aaa authorization exec default if-authenticated group tacacs+
aaa authorization commands 0 default local group tacacs+ if-authenticated
aaa authorization commands 15 default local group tacacs+ if-authenticated
aaa accounting update newinfo
aaa accounting exec default start-stop group tacacs+
aaa accounting exec LOCAL start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 0 LOCAL start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting commands 15 LOCAL start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
01-02-2003 05:50 AM
If you assign privilege level 15 to the user or group, EXEC authorization takes care of this with the service=shell, set-priv-lvl=15 Attribute Value Pair.
You have aaa authorization exec configured correctly, assign priv 15 and see if it works. If you do have it assigned and it is not working, let us know, there are some other issues that may be causing this....
01-02-2003 08:22 PM
I set the Service=shell and Privlege Level=15 on both the users and group levels areas of the ACS, and neither did the trick.
01-02-2003 09:31 PM
I forgot to mention that I'm using ACS for WIndows.
01-03-2003 02:59 AM
Does it work on vty (telnet) sessions and not the console? If so, try:
aaa authorization console
01-04-2003 02:58 PM
It doesn't work on vty connections. Before I added the ACS server, it was working on vty connections using local username and password authentication with the following AAA config.
hostname s1-carson
aaa new-model
aaa authentication password-prompt Password:
aaa authentication username-prompt Username:
aaa authentication login default local-case enable
aaa authorization exec default local none
aaa authorization commands 15 default local none
enable secret 5 ***** Text Removed *****
username ** removed ** psnet privilege 15 password 7 ** removed **
line con 0
transport input none
stopbits 1
line vty 0 4
length 25
line vty 5 15
01-05-2003 06:42 PM
Try changing:
to:
aaa authorization exec default group tacacs+ none
I think the if-authenticated is being used instead of the TACACS server attributes cause you have it first. In fact, the TACACS server will never be used for authorization with your current setup because the "if-authenticated" will always be used first and will never fail (unless authentication fails first).
01-07-2003 12:16 AM
Thanks that did the trick!!!
02-03-2003 11:19 AM
Hello:
A while back you had asked for assistance regarding setting up TACAS to the router logins to skip over to enable mode. I am currently trying to get this to work myself. Would it be possbile for you to post your working configuration (minus passwords of course), on the Cisco site? Also, any comments regarding what you had to do on the CiscoSecure site would be useful as well.
Thank you in advance.
02-04-2003 05:11 PM
This is part of EXEC authorization when the user logs in:
aaa new-model
aaa authorization exec default group tacacs+ local
tac server
username foo privilege 15 password bar
Assign the user or group privilege level 15 and away you go. You can use your local account if the connection to the tac+ server goes down or you receive an error for things like a key mismatch.
There are oodles of examples on cisco.com. Here is a good reference:
