Enabling RADIUS Auth/Acct on WLAN Controller 4402
kamrannaseem
Hi All,
Just need to enable RADIUS authentication and accounting on Cisco WLAN controller 4402, so that WLAN controller Admins can be authenticated via RADIUS server.
I want to make sure that i could log in via console or local user account, if RADIUS auth/acct on WLAN controller does not work for some reason. I dont want to lock myself out if RADIUS auth/acct does not work.
I have configured RDIUS for cisco 3750 switches and is working fine.
any suggestions please.
many thanks.
Kamran.
you need to set the order
Security > Priority Order > Management User
Network user is for wireless authentication.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
5 Replies 5
Jatin Katyal
RADIUS Server Authentication of Management Users on Wireless LAN Controller (WLC) Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml#wlc
The order of authentication for management users can be changed on the       WLC. In order to do this, from the
Security page on the WLC,       click  Priority Order > Management User
What radius server are you using? On the radius server you just need to push Radius IETF attribute service-type=administrative.
~BR
Jatin Katyal
~Jatin
Hi Jatin,
Thanks for your reply.
I am using  TekRadius 4.6. So if i check the management user box would it allow local user to login if RADIUS server fail to respond.
Most of the documents i found on the internet are for later versions but we are using WLAN controller software version 3.2 which is very old thats why i am bit conecenred that i dont lock myslef out once i enable RADIUS auth/acct.
Would you know what Network user  option does ?
many thanks.
~BR
Jatin Katyal
~Jatin
Hi Jatin,
I dont see any link or tab named Priority Order.
I have attached the GUI interface of my WLAN controller.
many thanks.
Yeah because the code you are running is pretty OLD. I couldn't find all these settings in WLC 3.2 configuration guide. http://www.cisco.com/en/US/docs/wireless/controller/3.2/configuration/guide/c32sol.html
WLAN code 4.2 does show that this feature.
Figure 5-5     TACACS+ Authentication Servers > New Page
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42sol.html
~BR
Jatin Katyal
~Jatin
