Generating license for ISE high availability primary/secondary nodes
michael_khadra
We have two ISE servers that will act as primary/secondary in a high availability setup.
The ISE 1.0.4 installation guide, page 93, mentions that "If you have two Cisco ISE nodes configured for high availability, then you must include both the primary and secondary Administration ISE node hardware and IDs in the license file."
However, after entering the PAK in the licensing page, the only required fields are:
- Primary Product ID
- Primary Version ID
- Primary Serial No
In this case, how can i include both primary and secondry HW and IDs?
Thanks in advance.
Naveen Kumar
Level 4
Level 4
I am refering you a Cisco ISE Nodes for High Availability configuration guide, Please check:
http://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_dis_deploy.html#wp1128454
chetra_phall
how can I get VID?
