10-16-2013 01:02 PM - edited 03-10-2019 09:00 PM
I put a customer on 802.1x using 4510. The CPU went up and trying to troubleshoot why. I have a similar setup some place else and everyhting is normal. Any ideas??
4510_SW#
4510_SW#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 15.0(2)SG7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 01-May-13 17:37 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1209444C
4510_SW#sh module
Chassis Type : WS-C4510R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 6 Sup V-10GE 10GE (X2), 1000BaseX (SFP) WS-X4516-10GE JAE114520LD
3 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE0930GHG7
4 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE0930GHFL
5 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE0930GKTN
6 48 10/100BaseTX (RJ45)V WS-X4148-RJ45V JAE0830R5F8
7 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE11430PXM
9 48 10/100BaseTX (RJ45) WS-X4148-RJ JAB04060C9K
10 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45 JAE0919BT9L
10-16-2013 04:25 PM
Did you notice any memory allocation error along with below listed error message in traceback
CHKPT-3-NOMEM: Unable to allocate resources for CF on (Get buffer failed).
If yes, then please review the symptoms of this defect. This is the most closest defect I could find.
CSCth73928 malloc errors following configuration of open auth
~BR
Jatin Katyal
**Do rate helpful posts**
10-16-2013 08:10 PM
i have not seen any errors like that...I will look into it, but not sure if this is the case..
02-19-2014 01:48 PM
to many DACL Entries.. I fixed the problem moving to VLAN instead of DACL
CCIE 18676
