01-09-2014 05:54 PM - edited 03-10-2019 09:15 PM
Hello
I am interested to know how the cisco ISE 1.2 base licences are consumed. As the cisco ise 1.2 user guide "The Base License is consumed whenever an authentication notification is received by Cisco ISE."
Based on the above statement i have following queries :-
Radius being the UDP based request, its only during the time endpoint is authenticated and authorized the base license is consumed and then its is released. Then how does cisco ISE tracks the concurrent endpoints connected to the network.
Kumar
01-11-2014 04:18 AM
All licensing in ISE is tracked by every radius authentication request.
Proper accouting of all licenses consumed relies on radius accounting for a proper count of all current radius connections.
Sent from Cisco Technical Support Android App
01-12-2014 03:23 PM
thanks for the reply Tarik.
As I understand, you mean that a base license is consumed by every radius authentication request and then the license is free to be utilised again
Also would this means if Radius accounting is turned off, then concurrent sessions will not be tracked.
Kumar
01-12-2014 06:27 PM
I am going to tell you a little secret about Cisco license count. According to Cisco documentation: http://www.cisco.com/en/US/docs/security/ise/1.2/user_guide/ise_man_license.html#wp1074423, it states:
License Count
The Cisco ISE license is counted as follows:
•A Base or Advanced license is consumed based on the feature that is utilized.
•An endpoint with multiple network connections can consume more than one license per MAC address. For example, a laptop connected to wired and also to wireless at the same time. Licenses for VPN connections are based on the IP address.
•Licenses are counted against concurrent, active sessions. An active session is one for which a RADIUS Accounting Start is received but RADIUS Accounting Stop has not yet been received.
Note Sessions without RADIUS activity are automatically purged from Active Session list every 5 days or if the endpoint is deleted from the system.
To avoid service disruption, Cisco ISE continues to provide services to endpoints that exceed license entitlement. Cisco ISE instead relies on RADIUS accounting functions to track concurrent endpoints on the network and generate alarms when endpoint counts exceed the licensed amounts:
•80% Info
•90% Warning
•100% Critical
Based on this assessment, you can purchase an ISE with 100 endpoint license and use the ISE to support 2000 endpoints without any issues because the license is not strictly enforce. Yes, it will generate alarms but it still works
01-12-2014 09:52 PM
Kumar,
The radius accounting allows ISE track the proper count of endpoints. If you do not enable radius accounting, you will see a growing number of endpoints which can lead to unecessary alarms.
Tarik Admani
*Please rate helpful posts*
