How does the acs adclient process work?
jamesky
Can someone explain how the adclient process works?  When you start and stop this service in the acs server , does it modifiy the computer entry in the AD ?
Tarik Admani
When you stop and start the service it tries to authenticate to the domain using the workstation account, it uses kerberos to gain access to the domain.
tarik Admani
Hi Tarik, what is the difference if you restart the box and if you manually start and stop? Does it have the same effect? Another question is.. does this manual stop and start modify the Computer entry inside the AD? Thanks.
