05-24-2012 09:00 PM - edited 03-10-2019 07:07 PM
Hi All,
I have a newly installed ACS 5.2 appliance integrated with our AD and its working with cisco products, switches routers and etc. Now i would like to include Juniper firewalls as well to be authenticated via ACS 5.2 either via ssh and web access. Can someone share me how to initiated this, policy creation.
fyi: i have 2 AD groups regionaladm and regionalops, read/write and read access respectively.
regards,
Marlon
Solved! Go to Solution.
05-25-2012 06:35 AM
Marlon,
I have pasted in a config below that I did for our ScreenOS firewalls to work with Cisco ACS v5.2. This config may not work since yours is Junos, but it might get you closer to figuring it out. Also, if you haven't been on the Juniper J-Net to ask around there, give it a shot. (forums.juniper.net)
Good luck!
--Chris
Title: Configuration Example - Juniper SSG and Cisco ACS v5.x
Product: Juniper SSG320M (Cisco ACS v5.x)
Version: ScreenOS 6.3.0r10.0 (Cisco ACS v5.2.0.26.8)
Network Topology:
[Juniper SSG320M]-----[Cisco 3560 Switch]-----[Cisco ACS VM]
Description:
Purpose - Authenticate SSG administrators using TACACS+ instead of local logins
Description - This configuration is for Cisco ACS v5.x, JTAC only had the v3.3 configuration.
ACS v5.x is a Linux-based VM with a completely new user interface and structure.
Configuration:
Configure the Juniper (CLI)
1. Add the Cisco ACS and TACACS+ configuration
set auth-server CiscoACSv5 id 1
set auth-server CiscoACSv5 server-name 192.168.1.100
set auth-server CiscoACSv5 account-type admin
set auth-server CiscoACSv5 type tacacs
set auth-server CiscoACSv5 tacacs secret CiscoACSv5
set auth-server CiscoACSv5 tacacs port 49
set admin auth server CiscoACSv5
set admin auth remote primary
set admin auth remote root
set admin privilege get-external
Configure the Cisco ACS v5.x (GUI)
1. Navigate to Policy Elements > Authorization and Permissions > Device Administration > Shell Profiles
Create the Juniper Shell Profile.
Click the [Create] button at the bottom of the page
Select the General tab
Description: Custom Attributes for Juniper SSG320M
Select the Custom Attributes tab
Add the vsys attribute:
Attribute: vsys
Requirement: Manadatory
Value: root
Click the [Add^] button above the Attribute field
Add the privilege attribute:
Attribute: privilege
Value: root
Note: you can also use 'read-write' but then local admin doesn't work correctly
Click the [Submit] button at the bottom of the page
2. Navigate to Access Policies > Access Services > Default Device Admin > Authorization
Create the Juniper Authorization Policy and filter by Device IP Address.
Click the [Customize] button at the bottom Right of the page
Under Customize Conditions, select Device IP Address from the left window
Click the [>] button to add it
Click the [OK] button to close the window
Click the [Create] button at the bottom of the page to create a new rule
Under General, name the new rule Juniper, and ensure it is Enabled
Under Conditions, check the box next to Device IP Address
Enter the ip address of the Juniper (192.168.1.100)
Under Results, click the [Select] button next to the Shell Profile field
Select 'Juniper' and click the [OK] button
Under Results, click the [Select] button below the Command Sets (if used) field
Select 'Permit All' and ensure all other boxes are UNCHECKED
Click the [OK] button at the bottom of the page to close the window
Check the box next to the Juniper policy, then move the policy to the top of the list
Click the [Save Changes] button at the bottom of the page
Verification:
Login to the Juniper CLI and GUI using an ACS Internal User account, and attempt to change something to verify privilege level.
05-25-2012 07:43 AM
On my SSG, I have the following:
set auth-server "Local" id 0
set auth-server "Local" server-name "Local"
On the SSG webGUI, I go to Configuration > Admin > Administrators and there is a drop-down for "Admin Auth Server." I have "Local/CiscoACS" selected. I don't know if your firewall has the same sort of setting, but that's the best I can come up with.
I hope it helps!
--Chris
05-25-2012 06:35 AM
Marlon,
Good luck!
--Chris
Network Topology:
Description:
Configuration:
Attribute: vsys
Value: root
Value: root
Verification:
05-25-2012 06:40 AM
thanks!!! this is very helpful, how to ensure that juniper will fallback to local account once acs is not available?
05-25-2012 07:43 AM
I hope it helps!
--Chris
