How to monitor Radius services on ACS 5.4
Hi All,
I want to monitor  Radius services of ACS 5.4,  In case of failure any radius service on ACS.
ACS should send alert to Syslogs  or email notification
Is there any way to monitor Radius services ? Anyone have any idea how to monitor.
Regards.
Hi Narinder,    I dont think
Hi Narinder,
   I dont think so there is any particular way you can do that, Because ACS 5.x doesnt have any particluar Radius service.
The services which are available and can be viewed through CLI and GUI are following:
  • Database
  • Management (ACS management subsystem)
  • Ntpd
  • Runtime (ACS runtime subsystem)
  • View-alertmanager
  • View-collector
  • View-database
  • View-jobmanager
  • View-logprocessor
htt    https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-ususer/guide/acsuserguide/viewer_sys_ops.html#pgfId-1052845
Cheers
Minakshi
Hello Minakshi,Thanks &
Hello Minakshi,
Thanks & appreciate your reply.. Can you please help me to provide  the Link again provided link is not able to open.Thanks.
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-4/user/guide/acsuserguide/viewer_sys_ops.html#pgfId-1052845
Cheers!!
Minakshi
Are there OID's that I can
Are there OID's that I can query to see if the services are up or down ?
  • Database
  • Ntpd
Tim,   On the ACS cli, You
Tim,
  On the ACS cli, You can run the following command:
#sh app status acs
I dont think so there are any OIDs.
Cheers!!
Minakshi(Rate the helpful posts)
43
