09-02-2013 11:33 PM - edited 03-10-2019 08:51 PM
We have recently purchased ISE devices, i initialized the ise device for the first time and run the Setup wizard.. but while the setup was installing ise application, we had power issue so my ise device got turned off and the ise application was not installed. now how can i re-run the setup and or how to install ISE-application ?
Please give me the instruction
Solved! Go to Solution.
09-03-2013 05:09 AM
If you are able to login in to ISE cli then you can configure the steps you missing initially . Check the following link for cli commands
http://www.cisco.com/en/US/docs/security/ise/1.2/cli_ref_guide/ise_cli_app_a.html#wp2096421
09-03-2013 07:02 AM
i have tried all above links, those are all for when u start ise for the first time.
I can normally login to my ise cli and can see the running config, but while i do sho app status ise, it says ise is not installed.
Although this should be very easy to solve but there is no such intruction by cisco . i couldnt find any doc dont know why cisco has not included it
09-03-2013 08:55 AM
Imran,
You will have to reimage the appliance to get the setup prompt back. There is no other way to do this.
Tarik Admani
*Please rate helpful posts*
09-02-2013 11:47 PM
If you are getting console then type Setup command on the console and if not then you have to do the whole installation again. Please follow the instruction given in the below link.
http://www.cisco.com/en/US/docs/security/ise/1.2/installation_guide/ise_ins.html
09-03-2013 12:06 AM
can u tell me How can i get a consol connection to ISE ? i couldnt find any instruction on this.
Im using cisco ISE 3315
09-03-2013 12:12 AM
sorry i m connected to its consol but i tried typing "setup" but it is not accepting that command
09-03-2013 12:18 AM
First you have to log in with admin username and password and then run setup. It would work. see the below link
http://www.cisco.com/en/US/docs/security/ise/1.0/install_guide/ise10_ins.html
09-03-2013 12:24 AM
Dear Ravi,
the above link is only for while you start configuring ISE devices for the First-time. and im already login through admin user, but there is no setup command availble.
09-03-2013 02:16 AM
anyone knows how to get this issue resolved ??? im totally stuck. I dont have any bootalbe dvd of my ise software to start booting from that dvd.
any help plz ?
09-03-2013 04:46 AM
Hi Imran,
Can you login int to the device via CLI.
If yes then you can configure what you want on this device.
You can see the status of the ise by issuning : sh application status ise
or paste the output of sh run:
Please also check this:
Sandeep
09-03-2013 05:09 AM
09-03-2013 07:02 AM
09-03-2013 08:55 AM
Imran,
Tarik Admani
06-07-2023 09:57 PM
that's right !
