11-09-2009 08:45 AM - edited 03-10-2019 04:47 PM
Hello. Install ACS 4.2 Build 124 Patch 13, I created three NDGs, My server has the IP 192.168.1.10, adding the same three NDGs server gives me this error:
An overlapping IP range 192.168.1.10 conflicts have been detected with ACS entry of 192.168.1.10.
besides, if you add a server with an IP that does not exist and then remove it, do not get such option to remove.
suggestions on this?
Solved! Go to Solution.
11-09-2009 12:39 PM
Make any change in the IP address of that server. Eg lets say IP is 192.168.1.1 , change it to anything like
192.1.1.1 submit and restart.
Go to control panel , admin tools, services...restart csadmin.
Now you should see aption to delete that aaa-server.
~JG
11-09-2009 12:03 PM
Hi Kevin,
There is no need to add server is all NDG's. You can place server in any NDG, that server will take care of all aaa-clients.
~JG
Do rate helpful posts
11-09-2009 12:32 PM
thank for reply, i try the delete AAA Server but not show the option delte!..what can i do?
11-09-2009 12:39 PM
Hi Kevin,
Please change the ip of the server to any random ip like 1.1.1.1 and submit the cahnges. After that go to start > run > services.msc and restart the Csadmin services. This would required re-login to ACS GUI.
Go to the same server > edit the changes and you would see delete + apply option.
NOTE: The above steps are only applicable for ACS windows.
JK
Plz rate helpful posts-
11-09-2009 12:39 PM
~JG
11-09-2009 12:47 PM
Thanks !!!.. now if I could delete it!.
