Inaccesible Authentication Bypass Feature Wrong Behaviour - CAT2960
ramiro_ortiz
I´m doing some tests with the new 802.1x authentication feaures in the CAT2960 switch and IOS firmware file 'c2960-lanbase-mz.122-25.SEE.bin'.
In particular, I´ve configured the 'Inaccesible Authentication Bypass' feature. What is wrong with it is that when the RADIUS server is not available I´m not redirected to the configured critical VLAN but to the default access VLAN configured in the port. I´ve checked out whether there´s some bug related but unsuccessfully.
The configuraction that I have is (summarized):
aaa new-model
aaa authentication dot1x default group radius none
aaa authorization network default group radius none
dot1x system-auth-control
dot1x critical recovery delay 2000
dot1x critical eapol
interface FastEthernet0/5
switchport mode access
dot1x critical
dot1x critical recovery action reinitialize
dot1x pae authenticator
dot1x port-control auto
dot1x timeout reauth-period 60
dot1x reauthentication
dot1x guest-vlan 5
dot1x auth-fail vlan 3
dot1x auth-fail max-attempts 2
dot1x critical vlan 6
spanning-tree portfast
radius-server dead-criteria time 30 tries 20
radius-server host 10.0.1.20 auth-port 1812 acct-port 1813
radius-server source-ports 1645-1646
radius-server key xxx
thomas.chen
Level 6
Level 6
I think based on the command "aaa authentication dot1x default group radius none " in your configuration, if the radius server is unavailable, you are not undergone into any authentication check. So, all are permitted without any authentication or authorization check.
Can you recheck this command to suit your requirement?.
jafrazie
The only thing I see that's missing is part of the radius-server definition:
It should look soemthing like:
radius-server host 10.0.1.20 auth-port 1812 acct-port 1813 [username blah key blah]
B/c you only have one RADIUS server defined, you need this test option test if the radius-server deadtime is not configured or not operational, b/c the dead-time is zero with only one server defined.
But the test option above should send a probe request to RADIUS before blindly considering it alive again.
End result, you SHOULD see something like this based on the rest of your config:
Switch#sho dot1x int f0/5 details
Dot1x Authenticator Client List
Supplicant = blah.blah.blah
Auth SM State = AUTHENTICATED
Auth BEND SM Stat = IDLE
Port Status = AUTHORIZED
Authentication Method = Dot1x
Authorized By = Critical-Auth
Operational HostMode = MULTI_HOST
Vlan Policy = 6
Hope this helps,
