08-21-2007 05:34 PM - edited 03-10-2019 03:20 PM
Has anyone had any luch with integrating CSM With ACS4.0?
I can authenticate a user but the problem is is it will only give level 1 privelige.
Is there any way to force the user to go to level 15?
I am using External database with Windows Authen.
Thanks in advance
08-21-2007 06:15 PM
Following link can help you configure CSM with ACS.
If using External Database make sure to do the Group mapping with right group, in order to get the right role/privilege.
~Rohit
08-22-2007 07:20 PM
Hi Rohit,
Thanks for your answer.
I have followed all of the procedures, but when I log in, I still only get level 1, where I actually want to log in as level 15...
Any idea?
08-24-2007 07:19 AM
Bring users/groups in at level 15
1. Go to user or group setup in ACS
2. Drop down to "TACACS+ Settings"
3. Place a check in "Shell (Exec)"
4. Place a check in "Privilege level" and enter "15" in the adjacent field
