IP Phone + dot1x + ACS 3.2
Hello everybody!
The main idea: I need to authenticate Cisco IP Phone connected to C3750 and put it into voice VLAN. Authentication in ACS v.3.2 using IP Phone's MAC-address.
There's port configuration on C3750:
interface GigabitEthernet1/0/2
switchport mode access
switchport voice vlan 12
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x host-mode multi-domain
spanning-tree portfast
end
In ACS I've created group "IP Phones" and in it's configuration I checked:
1) Voice-over-IP Support
2) IETF RADIUS Attributes:
[064] Tunnel-Type = VLAN
[065] Tunnel-Medium-Type = 802
[081] Tunnel-Private-Group-ID = 12
There's user 000d65707e7a (IP Phone's MAC-address) in this ACS group.
When I connect IP Phone to GigabitEthernet1/0/2 interface it don't get voice VLAN.
c3750#show mac-address-table interface gigabitEthernet 1/0/2
Mac Address Table
Vlan Mac Address Type Ports
1 000d.6570.7e7a STATIC Drop
12 000d.6570.7e7a STATIC Drop
In ACS choosing "Reports and Activity" -> "Failed Attemts" i see a mistake:
Authen failed - 000d65707e7a - Access denied to Voice-over-IP group
What's wrong? How to configure ACS group to authenticate IP Phone by it's MAC-address and put it into voice VLAN 12 on C3750?
Thanks for any help!
1 ACCEPTED SOLUTION
Re: IP Phone + dot1x + ACS 3.2
7940 will never do 802.1X. Neither will 7960. Newer phones will.
I think you need to add a radius VSA:
http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a00808abf2d.shtml
Also make sure your device-ID on the phone is same as the username you are putting (Not just the mac-address). It is in this format:
CP--SEP-
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/5_1/english/administration_sccp/guide/7961net.html#wp1041028
Please let me know how this turns out.
Farrukh
Thanks Farrukh for your help!
I've already learn these documents, did all the things in ACS and discovered that my IP Phone CP-7940G, firmware 8.0(7.0), do not support 802.1x-authentication.
Is there any other CP-7940G firmware with 802.1x feature enabled or I need to change model to 7961G (7970G)?
Using this port-config:
interface GigabitEthernet1/0/15
switchport voice vlan XXX
no logging event link-status
dot1x host-mode multi-host
dot1x timeout quiet-period 5
dot1x timeout reauth-period server
dot1x guest-vlan XXX
dot1x auth-fail vlan XXX
end
I achieved putting 802.1x-PC to needed access VLAN, non-802.1x IP Phone to voice VLAN and authenticate devices by MAC-address.
413
