12-30-2011 08:27 PM - edited 03-10-2019 06:40 PM
we have configured ipsec vpn cisco asa authentication by acs 5.1:
Here the config in cisco vpn 5580:
access-list acltest standard permit 10.10.30.0 255.255.255.0
aaa-server Gserver protocol radius
aaa-server Gserver (inside) host 10.1.8.10
key cisco
aaa-server Gserver (inside) host 10.1.8.11
key cisco
group-policy gpTest internal
group-policy gpTest attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value acltest
tunnel-group test type remote-access
tunnel-group test general-attributes
address-pool localpool
default-group-policy gpTest
authentication-server-group Gserver LOCAL
authorization-server-group Gserver
accounting-server-group Gserver
tunnel-group test ipsec-attributes
pre-shared-key cisco123
In the ACS, we config a group user: VPN users. all user VPN in that group. ACS have access policy: if user in group "VPN users", ACS permit access.
when we connect from a VPN Client to the server, all user connect success. When we see monitor log in ACS, each user success connect also get
error:
22040 wrong password or invalid shared secret
(pls see the attach picture)
the system still work but I dont know why we get the error log.
Thanks for any help you can provide!
Duyen
Solved! Go to Solution.
01-03-2012 10:46 AM
Hello Duyen,
I think I have narrowed the issue. When authenticating VPN Remote Access using RADIUS we need to keep in mind that the Authentication and Authorization are included on the same packet.
As per your configuration, the ACS is defined as a RADIUS server (aaa-server Gserver protocol radius) and the Tunnel Group for VPN is getting authenticated and "authorized" against that server:
As stated above, the RADIUS request/response includes Authentication and Authorization on the same packet. This seems to be a misconfiguration issue as we should not be configuring the "authorization" under the Tunnel Group.
Please remove the authorization under the Tunnel Group:
no authorization-server-group Gserver
Please test the connection again and verify the ACS logs. At this point there should only be one sucessful log reported on the ACS side.
The "authorization-server-group" is meant for LDAP authorization when authenticating against an LDAP server as well in order to retrieve the authorization attributes from the server. RADIUS does not need the command as explained above.
Hope this helps.
Regards.
12-31-2011 10:33 AM
Friend you have configured the same shared secret on both devices?
12-31-2011 05:57 PM
thank Jonatas,
But client success to connect to vpn server so I think key mismatch doesnt happen here.
01-02-2012 10:22 AM
have you got any idea to help me ?
thanks
01-03-2012 10:46 AM
Hello Duyen,
Hope this helps.
Regards.
01-05-2012 04:46 AM
thank, it work
