is it posible? two ACS 4.2 Appliance with the same remote agent
ACS-Appliance.jpgHello,
I have a ACS 4.2 Appliance integrate with Active Directory, CA and Remote Agent, i want to agregate another ACS 4.2 Appliance with the same configuration, the same Active Directory, CA. my question is: can i configure the another ACS with the same Remote Agent of the first? in other words ...
i attach the diagram.
Thank you
Ganesh Hariharan
Thank you
Maximum number of appliances supported—While a single Cisco Secure ACS Remote Agent can provide services to many Cisco Secure ACS Appliances, support is limited to five concurrent connections by the appliances served. For example, if you have three appliances that are primary Cisco Secure ACSes and three appliances that are secondary Cisco Secure ACSes used for failover purposes only, the remote agent can provide services to all six appliances and stay below the maximum of five concurrent connections.
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_installation_and_configuration_guide_chapter09186a0080193aa1.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
