Community Member
ISE 1.1.2 and certificates
Hello all,
i have a pretty simple setup, 2 admin/mon node and 2 PSN
Both PSN  have public cert installed and on the admin, i did add a private CA root cert.
Problem: the CA root cert was upgraded from a SHA1 to SHA256RSA. I imported the new CAroot to the CA store on the primary admin node and activated the 'trust for client authentication' but i get a: could not initialize eap-tls,eap-fast,peap. Both cert have the same name, same issuer
Question: Wich certificate are being uses for eap-tls authentication. should i delete the old one on CA store?
endpoint are still using sha1 and some sha256.
am i right to think that client to server is using the CAroot and server to client is using publicCert ?
Any hint would be grealty appreciated
Everyone's tags (1)
66
