Community Member
ISE 1.2.1 Advanced Licsense Consumption
Hi experts,
I run a ISE 1.2.1 (Patch 1 from Jul/14) with 5000 Base and 100 Advanced Licenses. I'm currently in phase of testing. I noticed that the advanced counter rises without any Advanced featue is used.I enabled profiling for the ISE nodes but I do not use this information in the policy. Posture and SGA is also not used so far.
All I do is matching against Internal hosts, Guest Portal and 802.1X
I hope you have an idea
Best Regards
Michael
1 ACCEPTED SOLUTION
Hello Michael-I think you are
Hello Michael-
I think you are hitting the following bug/defect: CSCuh36055
I have spoken with TAC about it and it will be fixed in v1.3
Thank you for rating helpful posts!
Hello Michael-
Community Member
Hey Neno! Thanks for your
Hey Neno!
Thanks for your answer :)
Best Regards
Michael
Silver
And what can he do until then
And what can he do until then? 100 licenses can be consumed quickly.
As of right now, ISE does not
As of right now, ISE does not enforce the license count. The administrator will start getting annoying alerts and notifications but it will not be service impacting. This can obviously change in the future but as of right now this is only causing a cosmetic defect.
74
