ISE 1.2 Guest Portal - Device registration portal
phaaring
I have a problem with the following setup:
- Cisco ISE 1.2 (latest patch)
- Cisco WiSM with 7.0.220.0 (first generation)
I have build Guest access via ISE. Because the WiSM's highest version is 7.0.X I used LWA with a redirect to the ISE guest portal. When using the Guest SSID with a iPad the client is redirected to the ISE guest portal and the user can enter his credentials (deliverd by the Sponsor). After clicking "Sign On" the client is forwarded to the "Device Registration Portal" of ISE and need to register his MAC address.
We have try a lot of differend settings but we cannot switch off the forward to the "Device Registration Portal". We only want to use the Guest User portal.
Please can someone help me to find a solution for this problem?
Thank you in advance.
Charlie Moreton
I know this might be reaching, but have you turned off the My Devices portal?
If so, an idea of the different settings you have already tried might help.
Please Rate Helpful posts and mark this question as answered if, in fact, this does answer your question.  Otherwise, feel free to post follow-up questions.
Charles Moreton
Thank you for the tip, I've tested this but it doens't solve the problem.
Naveen Kumar
Level 4
Level 4
I think you should disable in the DefaultGuestPortal (Administration  >> Web Portal Management >> Settings >> Guest >>  Multi-Portal Configurations >> DefaultGuestPortal >>  Operations  .... Uncheck the option Enable Self-Provisioning Flow
Yes nkumarsr - that's correct.
