ISE 1.2 NAC solution for 12500 Persona Deployment
Shakeeb AlDari
i have a deployment sceniro for  NAC solution ( ISE ) must support 12500 users and must provide the ability to implement security policies onendpoints before they connect so should i order ISE-3395 with ISE -3315 or its not a workable solution please advice
Aastha Chaudhary
Hi Shakeeb,
The total number of appliances needed in a deployment depends on multiple factors and not just the number of endpoints as described here :
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5712/ps11637/ps11195/guide_c07-656177.html
Refer to Step 2: Estimate the Number of Appliances or Servers Needed for the Deployment
We have a dedicated team at Cisco who deals with presales issues, I would advise you to contact them for more guidance. Here is their contact info :
• Phone: 408 902-4872
• Email: sac-support@cisco.com
• Live chat: http://tinyurl.com/sacise
Aastha
blenka
Level 3
Level 3
Aastha is correct you can contact SAC for the same with describing you requirement.
Naveen Kumar
Level 4
Level 4
ISE 1.2 with 3395 supports upto 10000 concurrent endpoints and ISE-3315 supports upto 3000 Concurrent endpoints.
So the quiestion is do you have a single location or multiple locations?
