09-02-2013 03:05 PM - edited 03-10-2019 08:50 PM
Please put default settings for alerts "ISE - Process Status" for CiscoISE (PAN / Operations / Alarms / Rules / Criteria / Monitor Processes).
For example, for version 1.1.4.218 for virtual machines.
Thanks in advance!
09-02-2013 07:34 PM
I would suggest you to go to below link.
http://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_ui_reference.html#wpxref92873
09-03-2013 02:33 AM
Hello Ravi!
Thank you for your answer!
I have studied this document before. Problem is that this rule comes a lot of alerts (every 2 minutes, all 6 exist nodas). Maybe it really is a error, but maybe it's just redundant messages, which set up the previous system administrator.
In an attachment - a screenshot of the messages (which arrive every 2 minutes), and a screenshot of current settings of criteria alerts - that was my question (which must be marked/cheked with checkboxes?)
09-03-2013 01:03 AM
You can view process status for the network from the Cisco ISE dashboard using the System Summary dashlet. For example, when processes like the application server or database fail, an alarm is generated and you can view the results using the System Summary dashlet.
One of the requirements for creating an alarm rule is that you assign it to a schedule. The following task shows you how to create an alarm rule, and then assign it to a schedule.
The following default alarm rules are shown in the user interface:
• ISE - AAA Health
• ISE - Process Status
• ISE - System Errors
• ISE - System Health
You can create these alarm rules using the following procedure:
• Passed Authentication
• Failed Authentication
• Authentication Inactivity
• Authenticated But No Accounting Start
• Unknown NAD
• External DB Unavailable
• RBACL Drops
For more information about configuration etc please go through this link:
http://www.cisco.com/en/US/docs/security/ise/1.1.1/user_guide/ise_ug.pdf
at page no.928
09-03-2013 02:38 AM
Hello Muhammad!
The problem I described in my post above.
If you have default settings for the criteria - put a screenshot here.
Thanks in advance!
09-03-2013 04:41 PM
Didn’t got your question, do you need the screen shoot of the ISE device or documented default settings? And yes if you are looking for doing some configuration changes as your question almost had covered the user guide.
09-04-2013 04:06 AM
Hello!
I'm interested in (screenshot) default settings for alerts "ISE - Process Status" for CiscoISE (PAN / Operations / Alarms / Rules / Criteria / Monitor Processes).
09-11-2013 12:40 AM
