08-31-2012 02:05 AM - edited 03-10-2019 07:29 PM
08-31-2012 02:22 AM
Why do you want to do that? Perhaps there is a better solution for your problem.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
08-31-2012 03:25 AM
I want to test that if the user is on the different IP group then she can access via the same ip pattern. That's it.
08-31-2012 01:30 PM
This is not supported. The other NICs are to be used as a probe, of if you are deploying an inline posture node, then nic 1 and nic 2 are used for the untrusted and trusted interface.
Tarik Admani
*Please rate helpful posts*
09-02-2012 12:55 AM
There can be up to 4 NICs defined on ISE
In ISE 1.1.1 the management interface can be accessed only on Eth0. However, ISE will listen on all defined NICs for RADIUS requests
I am not sure of the answer to your question on the default gateway and will check this out
