03-17-2014 02:24 PM - edited 03-10-2019 09:32 PM
I am working on getting ISE licensing requirements put together for the upcoming budget.
I am confused on licensing for a failover appliance. Do we need to get another set of licenses for the failover appliance, or will the licenses for the primary device cover the failover?
Solved! Go to Solution.
03-17-2014 03:19 PM
Prior to ISE Release 1.2, customers could only specify ISE licenses to be registered to a single ISE Administration Node (i.e., the Primary Administration Node). Now, ISE Release 1.2 delivers the capability to register ISE licenses to two Administration Nodes (i.e., Primary and Secondary Administration Nodes). The registration of an ISE license to the Primary Administration Node remains mandatory, but the option to register a Secondary Administrative Node is available.
Reference link,
http://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/sales_tool_c96-729045.html
03-17-2014 03:19 PM
Reference link,
03-18-2014 05:57 AM
Excellent!
Thank you for your swift response.
01-23-2015 06:23 AM
So an ISE license including both primary and secondary UDI is always necessary OR only necessary when the secondary admin node needs to be promoted a primary admin node?
01-21-2015 03:34 AM
Could You tell me please:
If I have two ISE physical appliances (3395 and 3495) . One of them is licensed, will HA and failover work ? Is there a difference if You use same appliance models or not?
01-21-2015 12:40 PM
The appliance models will not matter. Be sure to have both appliances licensed, though. Here is how to do that:
https://supportforums.cisco.com/discussion/12381521/adding-license-ise-secondary-admin-node
Charles Moreton
01-22-2015 01:24 AM
Thanks Charles, that's great!
Also, is it possible to do HA if You have one physical and one virtual (VM) ISE appliance?
Thanks!
01-22-2015 06:28 AM
Yes, you can mix Virtual and Physical Appliances.
01-23-2015 06:24 AM
