07-29-2013 04:24 PM - edited 03-10-2019 08:42 PM
Today I was installing ISE on 3355 appliances those will run all services (standalone), when installation completed I was not able to login to the CLI. I think the keyboard I used had issue (typed extra charachter or something). This was a pre-loaded OS.
I downloaded (ise-ipep-1.2.0-899.i386.iso) and tried password recovery booting appliance with (ise-ipep-1.2.0-899.i386.iso), after changing the password I saved configs and tried logging using the new password. But I could not login again.
Then I tried to re-install ISE using (ise-ipep-1.2.0-899.i386.iso). After the installation was completed, I entered setup command and an error poped up on the screen. "input/output errors occured while installation".
Question 1: Is the following iso only for a posture node installation or I could use this for ISE standalone deployment?
Cisco Identity Services Engine Software Version 1.2.0 full installation (IPN functionality only). This ISO file can be used for installing ISE IPN (Inline Posture Node) on ISE-33x5 and NAC-33x5 Appliances, SNS-3415 server and CSACS-1121.
Question:2 What could have caused "input/output errors occured while installation". And how should I proceed with the installation?
I am in really bad situation, your help and support will be highly appreciated.
07-29-2013 06:59 PM
Yes you are right the ise-ipep-1.2.0-899.i386.iso is used for installing ISE IPN. Might be you are using the corrupt software for Cisco Identity Services Engine. please download the latest software again. I installed the same and it’s working.
07-30-2013 10:19 AM
Hi Ravi, Thanks for the reply but my questions were following..
Can I use this ise-ipep-1.2.0-899.i386.iso for fresh installation on 3355 appliance?
Answer: Download the latest version 1.2 and check the MD5 checksum.
07-31-2013 01:18 AM
Hello Mudasir,
I am checking that you will be able to deploye it in standalone mode or not. I will update the thread as soon as possible.
08-29-2013 06:41 AM
If you wish to do a standlone deployment use
Cisco ISE Software Version 1.2.0 full installation(no IPN functionality).This ISO file can be used for installing ISE on ISE-33x5, NAC-33x5 Appliances, SNS-34x5 Servers and CSACS-1121 as well as a VM installation on VMWare ESX/ESXi 4.x/5.x
ise-1.2.0.899.x86_64.iso
09-18-2013 01:04 AM
Hi Mudasir,
Regarding Cisco ISE full deployment, please go through this link:
http://www.cisco.com/en/US/docs/security/ise/1.2/installation_guide/ise_ig.html
