ISE max-login-ignore-identity-response
Hi forumers'
Greeting, I had a question regarding ISE login identity response.
In my POC deployment, i'm using a single testing domain user account at the testing Active Directory. I able to login to the testing's secure network using the same user credential over normal workstation and handheld device (Ex: iphone, ipad etc),  SIMUTANEOUSLY.
How do i can strengthen the authorization policy where
1. ISE max-login identity response only allow to 2 concurrent connectivity on maximum one user per workstation and/or handheld device.
example:
AD user-A conencting to 1 unit of workstation and 1 unit of iPhone at the same time. If user-A trying to connect another iPad this time should make the connection fail.
Can i fine tune and strengthen on this, thanks
Noel
  • AAA Identity and NAC
725
