08-04-2012 11:41 AM - edited 03-10-2019 07:23 PM
I have downloaded the nac agents and compliancy modules to the ISE, and configured the client provisioning rules. The user guide doesn't really explain the next steps very good.
I guess because User Identity Groups are used in the policy, the provisioning is used with webauth, is that correct?
Solved! Go to Solution.
08-04-2012 11:48 AM
Jeppe,
The client provisioning is done with any authentication method. Either via dot1x or webauth, it is the authorization policy that starts this process. You redirect your clients the client provisioning portal using the authorization policy. Then you determine which agent (web agent, nac agent, or no agent) via the client provisioning policy.
Hope that helps,
Tarik Admani
*Please rate helpful posts*
08-04-2012 11:48 AM
Jeppe,
Hope that helps,
Tarik Admani
08-04-2012 01:46 PM
thanks alot. So I could do an authz policy saying redirect to webauth, and when the user login they will be asked to download the nac agent?
08-04-2012 02:06 PM
08-04-2012 02:33 PM
Thanks!
