Community Member
ISE Wireless endpoint license?
Hi all! Which means endpoint wireless license for Cisco ISE. Access point or client device? For example: I have 1 WLC, 35 access points and 500 clients. How many licenses I need to buy?
1 ACCEPTED SOLUTION
ISE licensing is based on
ISE licensing is based on endpoints authenticating to the network. So in your case if all 500 devices will be connecting to the network at the same time then you will need to purchase 500 licenses. Keep in mind that those are concurrent, thus, when a client leaves the network a license is freed up.
Hope this helps!
Thank you for rating helpful posts!
Community Member
Hi Tarasevich_Sergey1948, you
Hi Tarasevich_Sergey1948, you need to buy license for the number of active sessions. for more information please feel free to send me an email. so i can give you part numbers and a more detailed pricing.
Ferdinand Guasque
fguasque@cisco.com
Hope this helps!
Also refer " License
Also refer " License Consumption " from
http://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/datasheet-c78-730772.pdf
322
